Community Member
VG224 SCCP Sample Configuration
Does anyone have a sample SCCP configuration for a VG224 Gateway? I have the device set up in CallManager, but I know my configuration on the Gateway is probably not right. Can anyone help? Thanks
Community Member
Re: VG224 SCCP Sample Configuration
Give this a try
Community Member
Thanks for the reply...however this configuration is for MGCP, does anyone have one for SCCP?
Try this
stcapp ccm-group 1
stcapp
voice-port 2/1
caller-id enable
voice-port 2/2
caller-id enable
sccp local FastEthernet0/0
sccp ccm 1.1.1.1 identifier 1
sccp ccm 1.1.1.2 identifier 2
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
dial-peer voice 1pots
service stcapp
port 2/1
dial-peer voice 2 pots
service stcapp
port 2/2
Sankar.
PS: please remember to rate posts!
Community Member
It's still not working correctly. Is there more to this config that is missing? As soon as I pick up the handset I get a busy signal.
Can you paste a sh sccp output ?.
Community Member
SCCP Admin State: UP
Gateway IP Address: 10.1.40.6, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.1.40.11, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 11
Call Manager: 10.1.40.10, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 10
SCCP application services(dspfarm profiles) are not enabled
or haven't associated to SCCP CCM group
Community Member
Alright, got this working now. Anyone looking to do this configuration, please refer to this document.
http://www.cisco.com/en/US/customer/products/ps6441/products_feature_guide09186a0080483a76.html#wp1151347
3627
