VG224 SCCP SRST
Can anyone help i have configured a skinny vg224, and on my voice gateway i keep getting an ephone registering un-registering. The device shows in the vg224 as a
AutoCfg_Virtual_Endpoint Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 10.102.1.9, Port Number: 2000
TCP Link Status: CONNECTED, Device Name: AN1E4A540AA0FFF
Reported Max Streams: 0, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 20
I need to stop this device registering with my voice gateway.
Cheers
Re: VG224 SCCP SRST
It looks like you might have auto configuration enabled. Can you post any ccm-manager statements you have configured? I had the same problem one time.
Re: VG224 SCCP SRST
hi here is the sccp config
346
