VG224 SCCP Voice Quality Stats
is there some corresponding command to "mgcp voice-quality stats" for SCCP-controlled FXS ports?
I am missing CMR from these endpoints in CAR and CUSM. Though I don't think DSP may generate a MOS value, it should send Jitter, Lost Packets etc towards CUCM.
Sebastian
1 ACCEPTED SOLUTION
Hi Sebastian,
Could not find any corresponding commands for SCCP controlled FXS ports, however found the following
http://cdetsweb-prd.cisco.com/apps/dumpcr?identifier=CSCeh58624&parentprogram=QDDTS
FRE:For AnalogSkEndpoints to Support SkinnyStationStatistics Message
To Monitor the Call Statistics, we need analog skinny endpoints to support the StationConnectionStatistics Message. However, analog skinny endpoints currently do not support this message.
CSCeh58624 is an enhancement defect to request this functionality to be  incorporated for Analog Skinny Endpoints.
The enhancement is still open.
Manish
Hi Sebastian,
Manish
Hi Manish,
thanks for your reply.
Unfortunately I cannot open that defect due to issues with bug tracker.
Sebastian
230
