VG224 strange issue
I am facing some strange issue with Vg224, the device is added as SIP trunk on CUCM. All incoming and outgoing calls are working fine.
The issue is that when someone calls the analog phone, as soon the person answer the call he first hear some tone like some digits are dialed and then can hear the other party.
When normally analog phone is picked we get normal dial tone.
Any suggestions are much appreciated.
voice-port 2/17
echo-cancel coverage 32
cptone CN
timeouts interdigit 3
station-id number 12345
dial-peer voice 100 pots
description *** Analog User ***
translation-profile incoming CLASS-NATIONAL-Mobile
destination-pattern 12345
port 2/17
forward-digits all
1 ACCEPTED SOLUTION
Bronze
VG224 strange issue
Hi Anil,
You have configured "forward-digits all" under dial peer for FXS port. I suspect the tones you are hearing are DTMF tones of 12345 which is getting forwarded to analog phone because of forward digit all configuration. Kindly try removing "forward-digits all" from dial peer and then check.
Mohit Singh
Bronze
VG224 strange issue
Hi Anil,
Mohit Singh
VG224 strange issue
Thank you Mohit, You are right. It did fix the issue.
However I had to add no digit-strip cmd under pots dial-peer to make it work.
Thanks again.
146
