VG224 to a visa machine
Kindly I'm trying to connect a visa machine to a VG224
We are now running ios: vg224-i6s-mz.124-24.T.bin
It was vg224-i6s-mz.124-20.YA3.bin before trying the upgrade today
the path is as shown:
visa machine--------- VG224 [sccp,modem pass through]--------- cucm 6.0 ------------------ 2821 [ modem passthrough ]---------- PRI or FXO line
I have tried all configuration as i can but always failed
Having the visa machine to a direct line working fine [after eliminating the 9 from the visa machine setting]
Trying to make a voice call from an analog phone connected to the visa line,success
switching to modem relay failed also
So please advise what may be the issue with this machine
I have this conf in both the router and the VG:
voice service pots
fax rate disable
voice service voip
fax protocol none
modem passthrough nse codec g711alaw
voice-port 2/22
timeouts ringing infinity
dial-peer voice 23 pots
service stcapp
port 2/22
Thanks for your care
Best Regards
Hytham Hadad
Re: VG224 to a visa machine
Try this:
voice-port 2/22
input gain -5
output attenuation 5
voice service voip
fax protocol none
-nick
Hi Nick,
Thanks for your reply
But the problem still exist
If you're still having problems you may not be able to get the rate of the machine.
Chances are it's using V.30 or V.32 speeds, which are not officially supported on the DSPs.
You can sometimes get speeds higher than 14400 on the DSPs, but it's best effort.
If you drop the speed down on the modem you should be alright.
The previous suggestions are really all you can hope for if there isn't any packet loss or jitter in the call.
hth,
nick
Hall of Fame Super Gold
CC machines usually use very slow speed also to improve connection time.
Can you take "show controllers E1" on the PRI ?
So I won't be able to have my visa machines on the VGs without changing its rate ?
Also please find:
VoiceGW-1#sh control e1
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20060707, FPGA: 13, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (831 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
1 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
1 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 10 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations,
6 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
6 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Thanks & Best Regards
Hytham Hadad
Also please find:
E1 0/0/0 is up.
No alarms detected.
Hytham Hadad
You need to configure
network-clock-participate wic 0
network-clock-select e1 0/0/0
That alone might not solve the issue but please try as well.
Then using a regular phone off the VG you should collect info from "show call voice" to see if there is any loss or jitter in the network.
And, I would try h323 for the FXS port.
Hi Paolo,
I'll try it and feed you back
Also can i use h323 for a specific port on an sccp VG
I though for using MGCP for a specific port but found that i add the VG as sccp on the cucm, so don't follow on this
Hytham Hadad
297
