06-24-2008 12:38 AM - edited 03-15-2019 11:28 AM
Im tring to add some VG224 SCCP gateways via Excel Bat Tool. I Can Create the file format and everything is fine until Im tring to export the Data to BAT file format.
There is an error message: feature or method not supported
I tried it with other devices and it works fine. Only the VG224 doesnt work. What am I doing wrong?
06-24-2008 04:17 AM
Hi Mohamed,
If you are running a 6.x version of CCM, which I'm guessing you are, you are likely hitting the Bug referred to by Brent in this recent post.
Hope this helps!
Rob
06-24-2008 05:29 AM
Thank you I found out, that it works fine with the 6.0 Bat.xls file. But in the Job Scheduler I still get: "Could not insert new row - duplicate value in a UNIQUE INDEX column"
