Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
VG224 with Bulk "feature or method not supported"
Im tring to add some VG224 SCCP gateways via Excel Bat Tool. I Can Create the file format and everything is fine until Im tring to export the Data to BAT file format.
There is an error message: feature or method not supported
I tried it with other devices and it works fine. Only the VG224 doesnt work. What am I doing wrong?
Hall of Fame Super Red
Re: VG224 with Bulk "feature or method not supported"
Hi Mohamed,
If you are running a 6.x version of CCM, which I'm guessing you are, you are likely hitting the Bug referred to by Brent in this recent post.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc1009e/2#selected_message
Hope this helps!
Rob
Thank you I found out, that it works fine with the 6.0 Bat.xls file. But in the Job Scheduler I still get: "Could not insert new row - duplicate value in a UNIQUE INDEX column"
137
