VG224 with SCCP Question?.
I have a CCM 6.1.4 with two VG224 GW  using SCCP Protocol.  All features are working fine.
But I  got a question, it is possible to know what extension  does the  analog phone has configured on it , dialing a number or  pressing a key, my analog phone doesn´t have display screen.   In my  PBX i was able to know this.
Thanks in Advance.
1 ACCEPTED SOLUTION
Re: VG224 with SCCP Question?.
Unfortunately there is no such feature, the only way is via CCMadmin
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
java
java
Thanks for reply,   well  this really didn´t help me,  anyway thanks.
I fix  my problem  creating a  IPCCX  Script  and i achieve  it.
Best Regards.
Robert.
246
