VG224
Hello all
we have a problem with a VG224 Gateway. We connected it to our Callmanager
4.2(3) and configured some ports (MGCP). When we want to make a call from a
phone attached to the VG224 the destination phone rings and I can pick up the
call. However I don't get a voice connection. The call terminates and I get the
busy signal. After that I have to reboot the Port on the VG224.
What is the recomended IOS to run a VG224 on CCM 4.2(3)?
Has anyone a configuartion example for MGCP (and/or SCCP)?
Has anyone an idea??
Thanks Reto
Bronze
Re: VG224
Little confused - does that happen for all calls, or just some?
Re: VG224
Make sure your analog devices are in a Device Pool with a Region that is G711 to everything. I have seen this before when trying to use G729 on analog
Re: VG224
This happens to all calls on al ports of the VG224.
I can dial , the phone rings, pick up the phone the port on the VG224 disconnects and I get the dial tone (and have to reboot the port). This also happens in the other direction if I call a phone on the VG224.
Reto
Re: VG224
Hello
It seems that the problem is related to T.38 (see packet capture below):
No. Time Source Destination Protocol Info
34 7.574297 MGCP MDCX
205 AALN/S2/1@gw MGCP 0.1
Frame 34 (208 bytes on wire, 208 bytes captured)
Ethernet II,
Internet Protocol,
User Datagram Protocol, Src Port: 2427 (2427), Dst Port: 2427 (2427)
Media Gateway Control Protocol
MDCX (ModifyConnection)
Transaction ID: 205
Endpoint: AALN/S2/1@gw-test-fx1.hel.kko.ch
Version: MGCP 0.1
[The response to this request is in frame 36]
Parameters
CallId (C): A0000000010000b0000000F5
ConnectionIdentifier (I): A
RequestIdentifier (X): 9
LocalConnectionOptions (L): L: p:20, a:PCMU, s:off, t:b8, fxr/fx:t38
Packetization period (p): 20
Codecs (a): PCMU
Silence Suppression (s): off
Type of Service (r): b8
Unknown parameter: fxr/fx:t38
ConnectionMode (M): recvonly
RequestedEvents (R): L/hu
QuarantineHandling (Q): process,loop
36 7.577209 MGCP 510 205
fx: setting cannot be supported
Frame 36 (82 bytes on wire, 82 bytes captured)
Ethernet II,
Internet Protocol,
Response Code: The transaction could not be executed, because a protocol
error was detected. (510)
Transaction ID: 205
Response String: fx: setting cannot be supported
[This is a response to a request in frame 34]
[Time from request: 0.002912000 seconds]
Any ideas??
Thanks Reto
Re: VG224
Can you post the MGCP portion of your config? Do you have the command "mgcp fax t38 inhibit" in there?
Re: VG224
mgcp
mgcp call-agent cmt1 service-type mgcp version 0.1
That's the mgcp part of our config.
Reto
Re: VG224
Try adding the following lines and see how it goes...this is the config I had on a functioning VG224. Also, you may want to use the IP address of the CallManager rather than the hostname.
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
After you add and save the commands, reload the VG.
Re: VG224
We solved one part of our problem. We loaded IOS 12.4.13 to the Gateway and applied the commands recommendes in the Release Notes for Cisco Unified CallManager Release 4.2(3)
? no mgcp fax t38 inhibit
? mgcp package-capability fxr-package
? no ccm-manager fallback-mgcp
Everthing works fine with G729b codec. If we switch to PCMU (G711u) we can make calls from the Gatway to a phone using G711. However if I want to make a call to a analog phone attached to the VG224 with G711 the phone rings. I can pick up the phone but the caller gets a ringing tone from the gateway.
Any ideas why G711 behaves like this??
Reto
Re: VG224
Our Gateways work now with the following configuration
IOS: 12.4.8 (12.4.13 did NOT work)
Adding the following commands:
And everything worked.
Thanks for your help and support.
Reto
Re: VG224
HI, Can you please send me the working configuration of your VG224, 'cause i'm having a similar kind of problem with my box and I want to check the correct configuration.
email: ahmer74@hotmail.com
Thanks in advance
909
