VG244 Configuration
Dear Firends.
                   I need to configure vg244 analog gateway with Call manager 7.1.I would like to configure vg244 as SCCP gateway in call manager.So please provide configuration i need to do in VG244 and Call manager.
I am having 20 analog phones which having  dierectory number starting from 1500 onwords.
Thanks in advanse.
Naisamuddin PK.
Re: VG244 Configuration
You'll need to add the gateway within CUCM and specify the use of SCCP as the protocol. Once that is done, configure each individual port as you would an IP phone. Remember to specify an extension for each.
The process is covered in more detail  in the CUCM Admin Guide.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/b06gtway.html#wp1644973
-Felipe
I assume you are talking about a VG224, not a VG244 which doesn't exist.
Use this link for the IOS configuration side:
http://www.cisco.com/en/US/docs/ios/voice/fxs/configuration/guide/fxsbasic.html#wpxref30700
On CM, I don't have a handly link, but it's not really much different from adding a MGCP FXS port or an IP phone.  Device> Add Gateway> Choose platform.  Pick SCCP as the protocol.  Configure all the pertinent information, and assign a DN to each endpoint.  Reset the gateway from CM when done.
1315
