06-13-2007 09:53 AM - edited 03-14-2019 10:03 PM
Does anyone know if a VG248 config can be copied to a laptop and then restored ?
The VF224 is not a problem as it is similar to a router with a CLI but I cannot see a way of doing this on a VG248
Any ideas ?
Thanks.
06-20-2007 11:45 AM
) ftp into the vg248
2) type get user.cfg once you are in there.
3) change the name to something else when on your pc, say to olduser.cfg
Do a "more user.cfg" or "more olduser.cfg" to verify that the config has been pulled
accross.
4) ftp to the new vg248
5) type put olduser.cfg user.cfg.
Or you can Go to Diagnostics --> Show configuration and backup
06-20-2007 11:53 AM
WOW! I never knew that.
Is this a supported way to backup/restore a VG248?
I also see a user.cfg.xml file. What's that for? Is that created from the cfg file on bootup?
