Community Member
VG248-envmon
I am getting on vg248
"391 07:07:16    9m W EnvMon     3.3 volts supply too low: 3.053 volts", constantly.
Any idea how to troubleshoot this.. version on device are
Version
Software version : 1.3(2)
DSP firmware version : 3.6(25C)
Loader version : 1.0(1)
1 ACCEPTED SOLUTION
Re: VG248-envmon
That's a hardware bug (CSCse83429).  You either need to remove some devices off the VG224 so that the low voltage rail has less off a load on it, or you need to open a TAC SR to get it replaced with a unit that has the low voltage rail tweaked for more of a load.
1 REPLY
Re: VG248-envmon
364
