VG248 swap out
What do I need to do to swap out a VG248?
I conigures the IP address etc.., enabled the ports
Do I just configure the GW MAC address in CM and/or do I need to go into each DN and change the MAC as well?
Randall
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: VG248 swap out
Hi Randall,
Have a look at and make note of the specific settings on the VG (via console or telnet) before doing any changes. When you are ready you can go to the Device>Gateway Page on CCM and and change the MAC address from old to new and reset. You won't need to change the MAC for all the individual ports.
Hope this helps!
Rob
Re: VG248 swap out
Hi Randall,
Hope this helps!
Rob
Re: VG248 swap out
Thanks Rob,
That is what I thought. Just wanted to make sure.
Randall
Re: VG248 swap out
Hi Randall,
You are most welcome :)
Take care,
Rob
Re: VG248 swap out
Hi Randall,
I run the program in CM4.1(3) Pubscriber, it display"unable to locate mscoree.dll".
What CM version you are using? What stepes we use that program? please show us more information in details, thanks in advance!!!
Michael.
150
