VG248 to dialogic card
I have a vg248 that is connected to what is called a vipor system. This is basicly a dialogic card. The problem that I'm getting is at disconnect I'm getting ports stuck in off hook.
Talking to the company they are saying that there needs to be these setting on the lines need to be CPC signaling on all the lines must be adjusted between 0.4 - 0.6
Any ideas
1 REPLY
Re: VG248 to dialogic card
To finish the thread the problem ended up having to change the call supervision method to drop loop current. This caused the dialogic card to hang up.
171
