VG2821 with PeerAddress empty
Greetings All;
     I have a 2821 voice gateway using CUCM 6.1.5.   I had some cdr issues (didnt work) that I finally got sorted out.
I followed up by going onto the router to see the log history.
Lots of data, just missing a few pieces.   One main one is PeerAddress.    Its blank.   Missing this makes it hard tracing out a call in the logs when you cant figure out who made the call or its destination.
Searched high and low, didnt find anything on the subject.
I do have gw-accounting syslog enabled....   Ideas??
HELP!!
Tom
1 REPLY
Bronze
what is the call flow for which you are not able to see peeraddress (calling number)? Is it like
IP phone -- CUCM -- H323 -- VG -- PRI?
kindly provide below mentioned debug for a test call with calling and called number. I want to check whether the calling number is received by gateway or not
debug h225 asn1
debug voip ccapi inout
debug isdn q931
Also share the accounting file for the call and "show run" from router.
Mohit Singh
91
