Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
VG30D Craft Port access
Hi All, I have 2 VG30D's that are not accessable via the web interface so tried the craft RS232 port but still can't get any access - tested the cable - all OK. The guide says use the stubb RJ45 cross-over cable but the port is a old style 9Pin RS232 - any ideas how to access or a magic way to do a complete factory reset?
1 REPLY
Re: VG30D Craft Port access
It shouldn't be a cross-over cable.  It is likely either straight-through, or a rollover (1->8, 2->7, 3->6, etc).
Check out this link for DB-9 to RJ45:
http://www.cisco.com/en/US/partner/products/hw/routers/ps332/products_tech_note09186a0080094ce6.shtml
258
