VIC-2FXS not recognized in 3725??
I am using a Cisco 3725 router in my home lab as the PSTN.  I have a VIC-2FXS that I was trying to use on one of the three WIC slots however when typing a "sh run", "sh diag", or "sh ver" the 2 FXS ports do not show up.
I do have an NM-HDV module with the VWIC-2MFT-T1-DI in it, and its showing up in the config.  I havent tried putting the VIC-2FXS in the NM-HDV yet because, according to Cisco docs, the VIC-2FXS is supported on the 3 WIC slots.  I upgraded the IOS to Advanced Enterprise from IP VOICE and that did nothing.  I also have 4x PVDM12 on the NM-HDV module and the AIM-VOICE-30 installed on the motherboard.
On the 3700s, do they support VIC cards on the onboard slots?  Or do you have to put them on a NM-HDV module?
Side Note: The LEDs are showing amber on the VIC-2FXS so I dont believe its defective.
EDIT:  Thanks everyone, so the answer is No, its not supported on the 3725 natively (onboard WIC slots) and even on an NM-HDV, BUT you can buy a cheap NM-V1 or NM-V2 and it works.
Best scenario if you are using one as a PSTN switch, the NM-2V and (2) VIC-2FXS is the cheapest way to go.  You still have the bottom slot for the NM-HDV for staging PVDMs (no onboard PVDM slots) and 1 or 2 T1/E1/PRI cards and 2 on-board AIM slots to support the AIM-30-VOICE DSPs.
3 ACCEPTED SOLUTIONS
Blue
HI
You will need NM-1V or NM-2V module to support voice cards.
http://www.cisco.com/en/US/products/hw/modules/ps2617/products_tech_note09186a0080094ac0.shtml
Ronak Patel
Please rate helpful posts by clicking stars bewlo the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hall of Fame Super Gold
Blue
Re: VIC-2FXS not recognized in 3725??
As said, you will require NM-1V or NM-2V to make VIC-2FXS work with 3725. You cant insert it in other card and expect it to be detected.
Ronak Patel
Please rate helpful posts by clicking stars below the answer.
Blue
HI
Ronak Patel
Blue
HI
It is supported.
If you see the table and check 3700 column. It says  VIC-2FXS is supported on 3700 router with all the version.
Ronak Patel
I just put the VIC-2FXS in the NM-HDV and it still wasnt recognized.  There is documentation out there that states the 3700 supports the VIC-2FXS though, but I did see the table in this thread that said it didnt.  Strange...
Just to rule out the card itself, I put a VIC-2FXO in the NM-HDV slot and it didnt show up either.  However the VWIC-2MFT-T1 do show up on the onboard WIC slots and of course in the NM-HDV.
Looks like I will be buying a VIC2-2FXS...
Thanks for the help!
Blue
Ronak Patel
944
