VIC card for 2811 router
Dear
I have problem with VIC2B-S/T TE card (for ISDN BRI) which I try to connect to 2811 voice router with callmanager express.
IOS version is c2800nm-advipservicesk9-mz.124-20.T.bin and Cisco Unified Communications Manager Express 7.0(0) version.
In sh inventory I can't find VIC2B-S/T TE card, and appears error:
gt96k_mbrd_wic_interrupts_handle: Unexpected WIC intr, wic int status 0x3
in console.
Maybe card is unsupported.
Which VIC card is supported for cisco 2811 voice router?
BR,
Miroslav
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: VIC card for 2811 router
Always use VIC2-2BRI-NT/TE.
The NT feature is optional, default is TE.
You may not have the card that you think, or it may be damaged. Also check, "show diag".
Thank you.
This is part of the output of sh diag. Card is VIC-2BRI-S/T-TE=.
WIC Slot 2:
TE BRI Voice daughter card (2 port)
WIC module not supported/disabled in this slot
Hardware revision 1.0 Board revision G0
Serial number 33728859 Part number 800-03803-03
FRU Part Number VIC-2BRI-S/T-TE=
Test history 0x0 RMA number 00-00-00
Connector type Wan Module
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 14 01 00 02 02 A9 5B 50 0E DB 03 00 00 00 00
0x30: 80 00 00 00 05 06 23 01 FF FF FF FF FF FF FF FF
But my router doen't recognize this card. I can't find it in sh inventory.
Is this card supported for 2811?
BR,
Miroslav
You have a VIC- card that is not supported on the 2811. You need a VIC2- card. See:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00800e73f6.shtml
Which VIC2 card I can use, similar as VIC2-2BRI-NT/TE, but without network termination (NT), for European standrar use?
BR,
Miroslav
1042
