VIC Card in 2811
How do I tell if my router is recognizing the VIC-2FXO-M1 card I put in it? I want to confirm the card is working, but I don't know how to tell if it is working or recognized since I purchased it used.
Mitch
3 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
VIC Card in 2811
The command "sh inventory" should be the first step.
VIP Purple
VIC Card in 2811
Hi Mitchell,
In addition to what Mr Leo has said, u can also try show diag and also need to have Voice image .You should get the output something like Unknown Port Adaptor.
But ,I doubt the card is supported on 2800 series.
Please check the links
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00800e73f6.shtml
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800b53c7.shtml
regds,
aman
VIC Card in 2811
Aman seems to be right, this module is not supported on 28XX series
Voice Hardware Compatibility Matrix (Cisco 17/26/28/36/37/38xx, VG200, Catalyst 4500/4000, Catalyst 6xxx)
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
VIC Card in 2811
VIP Purple
VIC Card in 2811
Hi Mitchell,
regds,
aman
VIC Card in 2811
Br,
Nadeem
VIC Card in 2811
I get this when I run 'sh inventory'
PID: CISCO2811         , VID: V03 , SN: FTX2341A07T
Well that sucks if it doesn't support it. I was told it would because originally it had a T1 card in it and it has 4 WVIC slots 0-3.
I also have a 2821, but it doesn't have an IOS on it yet, waiting for the memory and CF card to arrive to update it.
VIC Card in 2811
I also ran 'sh diag' and I got this result:
WIC Slot 0:
        Unknown WAN daughter card
        WIC module not supported/disabled in this slot
        Hardware revision 1.0           Board revision F0
        Serial number     30276198      Part number    800-05298-01
        FRU Part Number     VIC-2FXO-M1=
        Test history      0x0           RMA number     00-00-00
        Connector type    Wan Module
        EEPROM format version 1
        EEPROM contents (hex):
          0x20: 01 2B 01 00 01 CD FA 66 50 14 B2 01 00 00 00 00
          0x30: 78 00 00 00 03 03 28 01 FF FF FF FF FF FF FF FF
VIC Card in 2811
Well, is there any VOIP card that will work in the 2800 (2811 or 2821) routers?
Thanks!
VIC Card in 2811
Does anyone have a suggestion for a VOIP device that is compatable with this card I can get on Ebay for relatively cheap? I see the list from this page, but it looks like some of the models need a special memory module to get as well:
Thanks all. I'd rather get the best item I can from the compatability list for the card, since it looks like most of them are relatively cheap, barring they don't require the additional memory DSP module.
VIP Purple
VIC Card in 2811
Hi Mitchell,
you can check your requirement from the above mentioned links.
Routers/Gateways
Model28012811, 2821, 2851
Voice Network Module (right)Not UsedNM-HD-1V 1NM-HD-2V 1NM-HD-2VE2NM- HDVNM- HDV2Chassis slot
VIC (below)
VIC-2FXO, EUNoNoNoNoNoNo
VIC-2FXO-M1/M2/M3NoNoNoNoNoNo
VIC-2FXSNoNoNoNoNoNo
VIC-2E/MNoNoNoNoNoNo
VIC-2BRI-S/T-TENoNoNoNoNoNo
VIC-2BRI-NT/TENoNoNoNoNoNo
VIC-2DIDYesYesYesNoYesYes
VIC-2CAMANoNoNoNoNoNo
VIC-1J1NoNoNoYesYesNo
VIC-4FXO-M1NoNoNoNoNoNo
VIC-4FXS/DIDYesYes3Yes3NoYes3Yes3
VIC2-4FXO (FXO/CAMA)YesYesYesNoYesYes
VIC2-2FXO (FXO/CAMA)YesYesYesNoYesYes
VIC2-2FXSYesYesYesNoYesYes
VIC2-2E/MYesYesYesNoYesYes
VIC2-2BRI- NT/TEYesYesYesNoYesYes
VWIC-xMFT-E1 (with or without DI)YesNoYesYesYesYes
VWIC-1MFT-G703YesNoNoNoYesYes
VWIC-2MFT-G703YesNoNoYesYesYes
VWIC-xMFT-T1 (with or without DI)YesNoYesYesYesYes
as far as Memory and Flash is concerned, install ipvoice image with yor existing DRAM/Flash & check.
regds,
aman
276
