VIC-FXS & VIC3-FXS
can you tell the differences between vic3-fxs cards and vic-fxs cards .They can be used interchangebly ?
thanks in advance
regards
V
1 ACCEPTED SOLUTION
Re: VIC-FXS & VIC3-FXS
Hi Vicky,
VIC-2FXS / VIC-4FXS/DID are 1st generation Analog Voice Interfaces. They are not supported on the new generation routers such as the ISRs. Whereas VIC3-2FXS/DID / VIC3-4FXS/DID are next generation and are supported on the ISR platforms. They are not backwards compatible. Kindly refer to the following data sheets which will give you more info:
Cisco 4-Port High-Density FXS/DID Analog Voice Interface
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a008010b355.html
Voice/Fax Network Modules for the Cisco 2600/3600/3700 Routers
http://www.cisco.com/en/US/products/hw/routers/ps259/products_data_sheet09186a0080091ba1.html
High-Density Digital Voice/Fax Network Modules for Cisco 2800/2900/3800/3900 Series
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet09186a00800921e7_ps274_Products_Data_Sheet.html
HTH. Please rate this post if it answers your question.
Harmit.
-- Regards, Harmit.
1 REPLY
Hi Vicky,
Harmit.
-- Regards, Harmit.
2232
