VIC2-2BRI-NT/TE - no voice port
I want to use a VIC2-2BRI-NT/TE with a 2811 router for trunking with a PBX but no voice port exists on the router. Do I have to create it somehow? The config looks like this:
show diag:
WIC Slot 0:
VIC2 - BRI-NT/TE Voice daughter card (2 port)
Hardware Revision : 1.1
Top Assy. Part Number : 800-21861-03
Board Revision : B0
Deviation Number : 0-0
Fab Version : 02
PCB Serial Number : FOC11286XWM
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : VIC2-2BRI-NT/TE
Version Identifier : V02
CLEI Code : CNUIAVZAAA
EEPROM format version 4
show run:
interface BRI0/0/0
no ip address
isdn switch-type basic-net3
isdn overlap-receiving
isdn protocol-emulate network
isdn layer1-emulate network
isdn incoming-voice voice
isdn sending-complete
isdn skipsend-idverify
show isdn stat:
Global ISDN Switchtype = basic-net3
ISDN BRI0/0/0 interface
******* Network side configuration *******
dsl 0, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 64, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
show ver:
Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
Hall of Fame Super Gold
Re: VIC2-2BRI-NT/TE - no voice port
You also need a DSP module, a minimum of PVDM2-8.
Tanks!
Same need, same issue,
1751V with wic 1bri S/T +
PVDM-256K-4
Should I use VIC BRI NT/TE card or a different dsp ???
You need VIC card for Voice.
WIC card is for WAN.
It was a newbie question.....
Tried with a VIC2B-NT/TE , it works like a charm ....
Thank you for the nice rating and good luck!h
Paolo,
As said my 1751V is now equipped with a VIC 2B NT/TE on slot 0 plus a PVDM-256K-4
All is working fine
I tried to install a VIC 2FXS card on slot 2
The system recognize both cards (show diag) but only voice port 2/0 and 2/1 are present on sh run
voice port 0/0 and 0/1 disappeared (the BRI port)
Why is this ??
Should I upgrade something (PVDM, RAM etc.)
Post "show inventory".
I've found this in official Cisco web resource :
Part NumberDescriptionNumber of DSPsSupported Voice Ports (Calls)
PVDM-44-channel PVDM12
PVDM-88-channel PVDM24
so a PVDM-4 can manage only two ports
for a further voice card  i need a PVDM-4 more (or replace the current one with a PVDM-8)
Thank you anyway
That is, as I had mentioned in my first answer above.
1037
