Community Member
VIC2 2BRI NTTE BRI ISDN status
The L2 for the ISDN line keeps going UP and down and it is State = MULTIPLE_FRAME_ESTABLISHED.
I have attached a file showing my BRI Config, and the errors I am getting. Is this a telco issue?
Hall of Fame Super Gold
Re: VIC2 2BRI NTTE BRI ISDN status
Hi, which IOS is this ? debug isdn q921 should give some more indication.
Community Member
The IOS verion is flash:c2800nm-spservicesk9-mz.124-11.XW2.bin
Debug isdn q921:
*Sep 3 20:11:14.219: ISDN BR0/0/1 Q921: User TX -> IDVER ri=0 ai=0
*Sep 3 20:11:16.215: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/1, TEI 0 changed to down
*Sep 3 20:11:16.215: ISDN BR0/0/1 Q921: L2_EstablishDataLink: sending SABME
*Sep 3 20:11:16.215: ISDN BR0/0/1 Q921: User TX -> SABMEp sapi=0 tei=0
*Sep 3 20:11:16.247: ISDN BR0/0/0 Q921: User RX <- UAf sapi=0 tei=0
*Sep 3 20:11:16.247: ISDN BR0/0/1 Q921: User RX <- UAf sapi=0 tei=0
*Sep 3 20:11:16.247: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/1, TEI 0 changed to up
*Sep 3 20:11:16.251: ISDN BR0/0/0 Q921: User TX -> IDVER ri=0 ai=0
*Sep 3 20:11:18.251: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/0, TEI 0 changed to down
*Sep 3 20:11:18.251: ISDN BR0/0/0 Q921: L2_EstablishDataLink: sending SABME
*Sep 3 20:11:18.251: ISDN BR0/0/0 Q921: User TX -> SABMEp sapi=0 tei=0
*Sep 3 20:11:18.283: ISDN BR0/0/0 Q921: User RX <- UAf sapi=0 tei=0
*Sep 3 20:11:18.283: ISDN BR0/0/1 Q921: User RX <- UAf sapi=0 tei=0
*Sep 3 20:11:18.283: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/0, TEI 0 changed to up
*Sep 3 20:11:18.287: ISDN BR0/0/1 Q921: User TX -> IDVER ri=0 ai=0
*Sep 3 20:11:20.287: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/1, TEI 0 changed to down
*Sep 3 20:11:20.287: ISDN BR0/0/1 Q921: L2_EstablishDataLink: sending SABME
*Sep 3 20:11:20.287: ISDN BR0/0/1 Q921: User TX -> SABMEp sapi=0 tei=0
*Sep 3 20:11:20.319: ISDN BR0/0/0 Q921: User RX <- UAf sapi=0 tei=0
*Sep 3 20:11:20.319: ISDN BR0/0/1 Q921: User RX <- UAf sapi=0 tei=0
*Sep 3 20:11:20.319: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/1, TEI 0 changed to up
to what are you connecting to ? There is no answer to IDVER packet. Try configuring 'isdn skipsend-idverify'.
hope this helps, please rate post if it does!
Community Member
i have no eyes on the site, working remotely. But I think the BRI cards are connected to a TA. The engineer says a cable from the telco terminates on a box, and from that box two cat 5 cables are termintated on the cards on the router.
the isdn skipsend-idverify command, is this a global or int bri command? and what does it do exactly
1st of all, Ethernet Cat 5 cables are wrong for BRI. The twisting of pairs is different. This may cause problem on lengthy wires, however it does not appear to be your case. Anyway a possibility is that the TA does not receive any data from router. Actually, if you are conecting to a telco circuit, the box is called an NT and not a TA.
Please rewire per standard BRI S/T pinout as specified in the interface manual.
The skipsend command, hidden in interface config mode prevents the router to use ID verify sequence that actually is standard in bringing layer 2 up.
Community Member
Thanks.
i tried the isdn skipsend-idverify command, and it stopped flapping. I am now able to make outbound calls on one of the ports.
However the other port L2 is TEI_Asigned. It is not the BRI Cards, as I swapped the cabling around and the working port went down.
what I have noticed is that both ports will not stay in multiple-frame established state. Whichever port I shut and no shut on, stays in established state and the other port is TEI_Assigned.
If i take out the isdn skipsend-idverify, both ports begin to go up and down again.
what is the link for the correct pin outs for BRI Voice Card?
Any more ideas. Thanks
Seems like a cabling issue. check:
http://cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a0080094b76.shtml
table for BRI S/T pinout, in short 3, 4, 5 and 6. If you only have cat 5 cable as opposed to flat cable, make sure pairs twist is on 3,4 and 5, 6. Do not connect the other pins.
Community Member
I've got a standard Cat 5 cable plugged into our BRI and that works fine. (UK, BRI connected to and ISDN2)
I didn't say it won't work, in fact it does, but because the pair twisting is different, you can have problem on longer distances.
Community Member
Well I shall remember that for future installations
Community Member
Hi.
Now i have the same problem of yuo
Are you repair this problem?
can you help me??
thanks
Alfonso
392
