VIC2-2FXO and VIC2-2FXS on cisco 2801
I am having Cisco 2801 router with IOS "cc2801-ipvoicek9-mz.124-20.T5.bin", i have installed VIC2-FXO on slot 2 [ this slot accepts only WICs and VICs] and VIC2-2FXS on slot0 [This slot only accepts VICs]
but the problem is that they both are not showing in show run and  show voice port summmary command.
i issued command show diag and found the below out for both slot:
VIC Slot 0:
        FXS Voice daughter card (2 port)
        WIC module not supported/disabled in this slot
        Hardware revision 1.1           Board revision B0
        Serial number     27276672      Part number    800-02493-04
        FRU Part Number     VIC-2FXS=  --------------------------why is it showing VIC-2FXS instead of VIC2-2FXO
        Test history      0x0           RMA number     00-00-00
        Connector type    Wan Module
        EEPROM format version 1
        EEPROM contents (hex):
          0x20: 01 0E 01 01 01 A0 35 80 50 09 BD 04 00 00 00 00
          0x30: 58 00 00 00 01 12 27 01 FF FF FF FF FF FF FF FF
        WIC/VIC/HWIC Slot 1:
        4 Port FE Switch
        Base MAC Address         : 001a.6d50.cbfc
        MAC Address block size   : 4
        PCB Serial Number        : FOC10484E9S
        Hardware Revision        : 6.0
        Part Number              : 73-8474-06
        Board Revision           : A0
        Top Assy. Part Number    : 800-24193-02
        Deviation Number         : 0
        Fab Version              : 05
        CLEI Code                : IPUIA00RAA
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : HWIC-4ESW
        Version Identifier       : V01
        Connector Type           : 01
        EEPROM format version 4
          0x00: 04 FF CF 06 00 1A 6D 50 CB FC 43 00 04 C1 8B 46
          0x10: 4F 43 31 30 34 38 34 45 39 53 40 00 56 41 06 00
          0x20: 82 49 21 1A 06 42 41 30 C0 46 03 20 00 5E 81 02
          0x30: 88 00 00 00 00 02 05 C6 8A 49 50 55 49 41 30 30
          0x40: 52 41 41 03 00 81 00 00 00 00 04 00 CB 89 48 57
          0x50: 49 43 2D 34 45 53 57 89 56 30 31 20 D9 02 C1 40
          0x60: 05 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC/VIC Slot 2:
        FXO Voice daughter card (2 port)
        Unknown EEPROM ver 16
        EEPROM format version 16
          0x20: 10 0D 01 01 01 A0 C2 85 50 09 BF 01 00 00 00 00
          0x30: A0 00 00 00 02 01 09 01 FF FF FF FF FF FF FF FF
        WIC/VIC/HWIC Slot 3:
        Serial 2T (12in1)
        Hardware revision 1.0           Board revision D0
        Serial number     35386517      Part number    800-03181-01
        FRU Part Number     WIC-2T=
        Connector type    PCI
          0x20: 01 12 01 00 02 1B F4 95 50 0C 6D 01 00 00 00 00
          0x30: 68 00 00 00 00 09 02 00 FF FF FF FF FF FF FF FF
please help!
Re: VIC2-2FXO and VIC2-2FXS on cisco 2801
zafar12233 wrote:
VIC Slot 0:
I assume that you mean VIC2-2FXS no -2FXO in the above quote.  The VIC-2FXS is not supported in your config.  Why the router is showing the incorrect part number in 'show diag' is a mystery.  Are you positive you have a vic2-2fxs and not a vic-2fxs?  The part number
800-02493-04
is the part number for a VIC-2FXS.  So, you will want to check VIC to ensure you do have a VIC2-2FXS.  If the VIC is labeled as VIC2 then you may want to contact Tac who can use the serial number to see if there was a defect in manufacturing or distribution.
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
VIC Slot 0:
        FRU Part Number     VIC-2FXS=  --------------------------why is it showing VIC-2FXS instead of VIC2-2FXS
yes i typed FXo By mistake, yes its labelled with VIC2-2FXS, i have one more card with same model number. its behaving the same.
OK.  Then contact TAC because the part number in your 'show diag' output is for a VIC-2FXS NOT a VIC2-2FXS.  At least, this appears to be the case from looking at my own lab.
HTH.
Bill
If you already checked the part itself and its a VIC2, we would need to check if the IOS that you are currently running supports this card, also another important detail to check is if you have DSPs to allocate to this card.
To check the version just do a "show run", and to see how many dps you have you could use the command "show voice dsp detail".
In this link you could find the minimun IOS to support each model of card
http://www.cisco.com/en/US/prod/collateral/modules/ps5365/product_data_sheet0900aecd801c595e.html
Please rate this post if was helpful
Walter Solano
CCNA Voice
Cisco UCCX Specialist
3270
