VIC2-2FXO and VIC2-2FXS on cisco 2801
zafar12233
I am having Cisco 2801 router with IOS "c2801-ipvoicek9-mz.124-20.T5.bin", i have installed VIC2-FXO on slot 2 [ this slot accepts only WICs and VICs] and VIC2-2FXS on slot0 [This slot only accepts VICs]
but the problem is that they both are not showing in show run and  show voice port summmary command.
i issued command show diag and found the below out for both slot:
VIC Slot 0:
        FXS Voice daughter card (2 port)
        WIC module not supported/disabled in this slot
        Hardware revision 1.1           Board revision B0
        Serial number     27276672      Part number    800-02493-04
        FRU Part Number     VIC-2FXS=
        Test history      0x0           RMA number     00-00-00
        Connector type    Wan Module
        EEPROM format version 1
        EEPROM contents (hex):
          0x20: 01 0E 01 01 01 A0 35 80 50 09 BD 04 00 00 00 00
          0x30: 58 00 00 00 01 12 27 01 FF FF FF FF FF FF FF FF
        WIC/VIC/HWIC Slot 1:
        4 Port FE Switch
        Base MAC Address         : 001a.6d50.cbfc
        MAC Address block size   : 4
        PCB Serial Number        : FOC10484E9S
        Hardware Revision        : 6.0
        Part Number              : 73-8474-06
        Board Revision           : A0
        Top Assy. Part Number    : 800-24193-02
        Deviation Number         : 0
        Fab Version              : 05
        CLEI Code                : IPUIA00RAA
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : HWIC-4ESW
        Version Identifier       : V01
        Connector Type           : 01
        EEPROM format version 4
          0x00: 04 FF CF 06 00 1A 6D 50 CB FC 43 00 04 C1 8B 46
          0x10: 4F 43 31 30 34 38 34 45 39 53 40 00 56 41 06 00
          0x20: 82 49 21 1A 06 42 41 30 C0 46 03 20 00 5E 81 02
          0x30: 88 00 00 00 00 02 05 C6 8A 49 50 55 49 41 30 30
          0x40: 52 41 41 03 00 81 00 00 00 00 04 00 CB 89 48 57
          0x50: 49 43 2D 34 45 53 57 89 56 30 31 20 D9 02 C1 40
          0x60: 05 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC/VIC Slot 2:
        FXO Voice daughter card (2 port)
        Unknown EEPROM ver 16
        EEPROM format version 16
          0x20: 10 0D 01 01 01 A0 C2 85 50 09 BF 01 00 00 00 00
          0x30: A0 00 00 00 02 01 09 01 FF FF FF FF FF FF FF FF
        WIC/VIC/HWIC Slot 3:
        Serial 2T (12in1)
        Hardware revision 1.0           Board revision D0
        Serial number     35386517      Part number    800-03181-01
        FRU Part Number     WIC-2T=
        Connector type    PCI
          0x20: 01 12 01 00 02 1B F4 95 50 0C 6D 01 00 00 00 00
          0x30: 68 00 00 00 00 09 02 00 FF FF FF FF FF FF FF FF
please help!
Leo Laohoo
You need IOS version 12.4(20)T.
Cisco IP Communications Voice/Fax Network Module
http://www.cisco.com/en/US/prod/collateral/modules/ps5365/product_data_sheet0900aecd801c595e.html
Please don't forget to rate useful posts.  Thanks.
I have managed to arrange the IOS "c2801-ipvoicek9-mz.124-20.T5.bin", but still the same problem.
please help!
experts! i would appreciate the quick response
