06-02-2008 06:16 AM - edited 03-15-2019 11:00 AM
I installed a VIC2-2FXO= into my 3845 router and am unable to configure the voice-port. I keep getting "unrecognized command" or "invalid input detected..." when I enter the following:
flmai002-r02(config)#voice-port 0/3/0
% Invalid input detected at '^' marker.
I have another 3845 which has the exact same card installed and it is working fine. I have already tested the card to see if it was bad and it is good and works in the other router. The ios versions are the same on both routers too. I have tried all 4 sub-slots in slot 0 on the router and get the same result. Could I have a bad slot 0 in this router or am I just missing some enable command for the card? Please help. I attached a text file of the show inventory command for reference.
Solved! Go to Solution.
06-02-2008 06:46 AM
For the voice cards to work you need to have DSP resources available on the router which is in form of PVDMs.
Your card has ben deteted properly by the router.
Check if you have enough DSPs on the router and paste the show diag output here.
-> Sushil
06-02-2008 06:59 AM
When you do a show diag and you have PVDM installed, your output should look like this, for example:
PVDM Slot 0:
64-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Check this to see how to install and remove PVDMs in 3800 series router:
http://www.cisco.com/en/US/docs/routers/access/3800/hardware/installation/guide/38comp.html
- adrián.
06-02-2008 07:26 AM
Hi friend,
This info can help you:
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/htpvdm2.html#wp1049404
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8016a8e8.html
- adrián.
06-02-2008 07:39 AM
If you need info about DSPs and PVDM:
Regards.
06-02-2008 06:33 AM
Hi friend,
Check with show diag if you have a PVDM installed in your router. If you don't have any installed, its not possible to use voice-ports.
- adrián.
06-02-2008 06:42 AM
Ok, I see PVDM on the router that has the working fxo card but not on the one in question. How am I supposed to get this PVDM in the router? Is it another card or software?
06-02-2008 06:46 AM
Yes its another module on the router which get istalled on the PVDM slot of the router.
06-02-2008 06:50 AM
Hi friend,
Check this link to see what are PVDMs.
Installing and Upgrading Internal Components in Cisco 3800 Series Routers:
When you plan to use your router as voice gateway, you have to purchase it with PVDMs. If your router actually doesn't have PVDM, you have to buy it.
- adrián.
06-02-2008 06:46 AM
-> Sushil
06-02-2008 06:51 AM
Ok, here is the show diag output. I am a bit confused about PVDM whether it is another card I have to install before I install the vic2-2fxo card? You mention DSP resources being available. Could it be that I have too many cards installed in this router? The fxo card is the only card in slot 0.
06-02-2008 06:59 AM
PVDM Slot 0:
- adrián.
06-02-2008 07:26 AM
Hi friend,
- adrián.
06-02-2008 07:39 AM
Regards.
06-02-2008 07:52 AM
Thanks for all the help. I opened up a spare router and noticed that all the pvdm slots were empty. Then I looked at Cisco for pricing and found that there is a voice bundle that you can choose when ordering the 3845 routers which includes the pvdm modules already installed. I am ordering the modules today for install so we can finish the configuration of the fxo card.
06-02-2008 08:00 AM
Hi friend,
Glad to see that your configuration will work very soon!
- adrián.
06-04-2008 08:33 AM
you'll have to do this off hours because you will have to shut down the router.
