vic2-2fxo not supported in 2811?
i have a nm-hdv in slot one and a vic2-2fxo in the module. this 2811 has four hwic slots - can i put the vic2-2fxo in an hwic?
sh diag
Slot 1:
High Density Voice Port adapter
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.1
Top Assy. Part Number : 800-03567-01
Board Revision : G0
Deviation Number : 0-0
Fab Version : 02
PCB Serial Number : JAE07420BVK
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : NM-HDV=WIC Slot 0:
VG - FXO Voice daughter card (2 port)
WIC module not supported/disabled in this slot
Hardware Revision : 5.0
Top Assy. Part Number : 800-21597-01
Board Revision : E0
Fab Version : 04
PCB Serial Number : FOC09301FGD
RMA History : 00
Version Identifier : V
Product (FRU) Number : VIC2-2FXO=
thanks in advance.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: vic2-2fxo not supported in 2811?
That is what I was telling you ... The ISR routers are really made to work this way ...
Yes, but you need the DSP modules on the router mainboard. The smaller is PVDM2-8 and will support 8 voice channels.
ok - im configuring this as a 911 line at a remote site. ill dig up DSP's and give it a shot.
thanks for the reply.
i have a pvdm2-64 sitting in a nm-hdv2-2t1/e1 - will this work?
Yes, although hugely oversized.
you said to put the pvdm2 on the motherboard and not on the nm-hdv?
i already have dsp on the motherboard.
PVDM Slot 0:
16-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8538-05
Board Revision : B0
Fab Version : 04
PCB Serial Number : FOC1144176Z
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-16
Version Identifier : V01
EEPROM format version 4
PVDM Slot 1:
48-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Part Number : 73-8540-05
Board Revision : B0
Fab Version : 04
PCB Serial Number : FOC11372FMR
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-48
EEPROM contents (hex):
analog cards are not supported on NM-HDV per the link below.
http://www.cisco.com/en/US/customer/products/hw/routers/ps259/products_tech_note09186a00800e73f6.shtml
i'm going to try a chassis slot.
so i ended up removing the nm-hdv from slot 1 in the 2811 and adding the VIC2-2FXO in hwic slot 3 and the router found it - no more errors during a sh diag.
thanks.
873
