Community Member
VIC2-2FXO
Hi All,
we need to install VIC2-2FXO card on Cisco 2901 router .
On cisco 2901 router, we would configure as MGCP and we do not have any BRI/PRI link on the router.
Is it possible to make the solution work or we need to configure Voice Gateway as H.323 ?
Any ideas?
Rebecca...
VIC2-2FXO
Hi Rebecca,
You can use 2901 with VIC2-2FXO configured for MGCP. I have seen such deployments.
Manish
Community Member
VIC2-2FXO
Hello Manish,
Thanks for your reply..
Could you please help me with any such supported documents? or any link which I could follow and configure the same..
Rebecca...
VIC2-2FXO
Here is a good link with details of config on gateway and cucm
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008009428e.shtml
Manish
VIP Super Bronze
VIC2-2FXO
Don't forget that the router will also need sufficent PVDM3 resources for the FXS ports to work.
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
407
