VIC2-2FXS card problem
gijuacisco
Dear friends,
I have Cisco 3945 router. I inserted in this router VIC2-2FXS card, but the interface is not visible in the configuration.
What is the problem? Do you have any advice? Is it neccessary to change IOS?
Best regards,
Mamuka
2 Accepted Solutions
Gajanan Pande
Mamuka,
Usually in such queries, attaching " show tech " ouput of the router would help immensely. Looks like the card is not detected, " show diag " output should give the hint.
If you dont mind, attach " Show Tech " output of the router so that we can pinpoint the fault.
Pls remember to rate helpful posts.
GP.
VIC2-2FXS card is very much compatible/supported with 3945. In your case, looks like you inserted this card without any network modules. Pls use NM-HD- type of network module & then insert the VIC2-2FXS card on the NM. Thus you should be able to configure it without any issues.
GP.
Gajanan Pande
Mamuka,
GP.
Dear GP,
The card is detected. Here is the show diag:
        WIC Slot 0:
        2nd generation - FXS Voice daughter card (2 port)
        WIC module not supported/disabled in this slot
        Hardware Revision        : 3.1
        Top Assy. Part Number    : 800-21341-02
        Board Revision           : B0
        Deviation Number         : 0-0
        Fab Version              : 01
        PCB Serial Number        : FOC11343ULZ
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : VIC2-2FXS
        Version Identifier       : V01
        CLEI Code                : CNUIAPPAAA
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 00 47 41 03 01 C0 46 03 20 00 53 5D 02
          0x10: 42 42 30 80 00 00 00 00 02 01 C1 8B 46 4F 43 31
          0x20: 31 33 34 33 55 4C 5A 03 00 81 00 00 00 00 04 00
          0x30: CB 89 56 49 43 32 2D 32 46 58 53 89 56 30 31 20
          0x40: C6 8A 43 4E 55 49 41 50 50 41 41 41 FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
But there is no "voice-port" in configuration and I can't configure it.
I want to mention that IOS is: "flash0:c3900-universalk9-mz.SPA.150-1.M1.bin"
Is it possible that VIC2-2FXS card I have isn't compatible with the router 3945?
This card worked in the router 2811.
GP.
I just found that the VIC2-2FXS is not compatible/supported for 3900 series router. I need VIC3-2FXS/DID.
You can see in the table:
thanks.
