VIC2-4FX0 in 3745
Is 3745 router support VIC2-4FX0?
I can't see any 4FX0 in show version.
thanks,
gerard
Hall of Fame Super Red
Re: VIC2-4FX0 in 3745
Hi Gerard,
We don't use any 3700 series but according to the documentation the VIC2-4FXO is supported. Have a look;
Cisco 3700 Series Multiservice Access Routers
Relevant Interfaces and Modules
Analog Voice Interface Cards - VIC2-4FXO
From this doc;
http://www.cisco.com/en/US/products/hw/routers/ps282/products_relevant_interfaces_and_modules.html
IP Communications Voice/Fax Network Module Datasheet
From this doc;
http://www.cisco.com/en/US/products/hw/modules/ps5365/products_data_sheet09186a0080191d41.html
Hope this helps!
Rob
Also note that 3700s dont have onboard dsp slots, so you will need to rely on aim-voice-30 card if you want to use this card on a regular wic slot, or else use a NM-HDV2 to use that vic.
Sankar
PS: please remember to rate posts!
331
