07-05-2007 10:32 AM - edited 03-14-2019 10:25 PM
Hi everyone, i am new to this site...
I just installed 2x VIC2-4FXO on a 2801 router, on the 1st card, the last port (0/0/3) have the IN USE amber led on since I installed the card, but much brighter than normal... and the port isn't working at all. Any suggestion ?
Software version, 12.4(11)XJ3
07-05-2007 05:40 PM
Perhaps it got stuck. Try shut no/shut the voice-port, but if it stays like that you have to reload the router. If it stays like that and no line connected, is defective.
07-05-2007 06:40 PM
i tried shutdown and no shutdown couples of time before, didn't help, but this problem appeared when I installed this card few weeks ago (brand new router with brand new card). I also reloaded the router couple of time since then... I was wondering if there was a way to hard reset the card ... I guess it is defective ! thanks for the reply !
I am also having an issue with thoses external FXO port, poor line quality, bad audio and i am also having a delay between the time i dial an external number to the PSTN and the connection, about 5 sec...
07-05-2007 06:50 PM
for the bad audio, please follow the guide for doing a THL tone sweep with auto settings, at:
http://cisco.com/en/US/tech/tk652/tk701/technologies_tech_note09186a0080477a06.shtml
for the post dial delay, configure dial-peer without the T for fixed length numbers. Os set timeout interdigit lower in telephony-service.
07-05-2007 08:33 PM
Thanks ! this was exactly what i needed !
By the way, do someone know how to get either a RMA number, factory repair or replacement of the defective FXO card? Reseller said that i am on my own with this...
Thanks again !
