VIC2BRI disconnect criteria [SOLVED]
HI,
I'm using an old 1751V with a VIC2B-NT/TE as ISDN gateway for a IP pbx
My problem is:
When a remote caller  calls my phone number through ISDN network , the call is answered by pbx extension . If the remote caller hangs up , the whole call chain (ISDN line--bri port---voip trunk---extension) is disconnected properly.
When a pbx extension places a call to a remote party via ISDN (also to the same phone number that was the caller in previous example) and the voice connection is established, if the remote called party hangs up,  the line is not disconnected like before , instead the disconnect tone from ISDN telephon exchange is heard while the whole chain is still up (the call ends for timeout 30 seconds later).
Is this a 1751V configuration problem or a ISDN network one ??
This is my actual (poor) config on 1751V :
no voice call carrier capacity active
interface BRI0/0
 no ip address
 isdn switch-type basic-net3
 isdn incoming-voice voice
 isdn answer1 <myphonenumber>
voice-port 0/0
 compand-type a-law
 cptone IT
dial-peer voice 1 voip
 destination-pattern <myphonenumber>
 session protocol sipv2
 session target ipv4:<mypbxIP>
 session transport udp
 dtmf-relay rtp-nte
 codec g711alaw
 no vad
dial-peer voice 11 pots
 destination-pattern 3T
 no digit-strip
 port 0/0
dial-peer voice 10 pots
 destination-pattern 0T
 no digit-strip
 port 0/0
dial-peer voice 20 pots
 incoming called-number <myphonenumber>
 direct-inward-dial
Thank you for any hint !!
Hi,I think it is in the
I think it is in the Gateway BRI configuration. I had the same issue in a H323 gateway.
Try:
 isdn send-alerting
 isdn sending-complete
under BRI interface
Green
Hi,Sounds like the the
Sounds like the the disconnect message in the Q931 is being ignored by the router.
Add this to the global config, retest
voice call convert-discpi-to-prog
Hope this helps
Alex
Regards, Alex. Please rate useful posts.
Thanks for
Thanks for replies
Unfortunately none of these suggestions work
I'm going to debug q931 if helps....
Any idea well accepted
Finally solved !Alex you was
Finally solved !
Alex you was close to it...
the command to add is
voice call disc-pi-off
It works perfectly now
Hope it helps
Thank you again.
21
