VIC3-2FXS/DID VS VIC3-2FXS-E/DID
hi all,
we'll upgrade our router from 2811 to 2911.
the current 2811 uses VIC2-2FXS but saw on cisco's website that we need a VIC3 instead.
i saw there's two versions of this card, the other has an 'E'.
what's the difference between the two? can i just get a VIC3-2FXS/DID?
1 ACCEPTED SOLUTION
Hi John,Yes, you can use VIC3
Hi John,
Yes, you can use VIC3-2FXS/DID with 2900 series routers.
Manish
Hi John,The difference is
Hi John,
The difference is explained in the following link
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/ip-communications-voice-fax-network-modules/product_data_sheet0900aecd801c595e.html
VIC3-2FXS-E/DID is designated as an "Off-Premise Extension Lite" product offering. This means that while the module addresses a subset of the off-premise extension applications, it should be noted that the module is not in full compliance for off-premise usage.
Manish
hi manish,thanks for the link
hi manish,
thanks for the link! i'm not really a voice guy so my other question is that, can i just get a VIC3-2FXS/DID instead?
Hi John,
Manish
thanks for confirming!
157
