Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
VIC3-4FXO/DID module not detect in 2801 Router.
Hi Team,
I have Cisco 2801 router with 2 DSP 16 Channel, 128 MB DRAM and 128 MB flash. I am using IOS c2801-spservicesk9-mz.124-3i but the VIC3-4FXO/DID module is not detected. I tried to upgrade the IOS to 15.0 and 15.1 but the router is not boot up due to insufficient memory.  In that IOS the FXO card is detected.  I checked the data sheet of both router and FXO card it support 12.4T IOS but when I upload the IOS and try to boot same problem I have faced (router not boot due to insufficient memory).  Kindly help me find out the appropriate IOS to resolve the issue.
Thanks in advance.
Manas Ranjan
VIP Purple
Hi Manas, I was trying to
Hi Manas,
I was trying to find the support for VIC3-4FXO card on 2801 router. What I could find that VIC3 cards require IP Voice image with IOS version 12.4(20)T or 12.4(15)XW.
even though 12.4(15)XW is not available but 12.4(15)XY  is available but IP voice image requires minimum 192MB DRAM with 64 MB Flash.So , u need to upgrade the DRAM.
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/ip-communications-voice-fax-network-modules/product_data_sheet0900aecd801c595e.html
regds,
aman
VIC3-4FXO card is not
VIC3-4FXO card is not supported in 2801 according to table4
Table 4. Software and Memory Requirements for Voice/Fax Network Modules and Voice Interface Cards
Product
Cisco 2800 Series
Cisco 3800 Series
Cisco 2900 and 3900 Series
NM-HD-1V
NM-HD-2V
NM-HD-2VE
• Cisco IOS Software
• Release 12.3(8)T4
• "IP Voice" images
• Release 12.3(11)T
• "IP Voice" images
• Cisco IOS Software Release 15.0(1)M
• "UC Technology" images
VIC2-2FXO
VIC2-4FXO
VIC2-2BRI-NT/TE
• Release 12.3(8)T4
• "IP Voice" images
• Release 12.3(11)T
• "IP Voice" images
VWIC2-xMFT-xx
• Release 12.3(14)T
• "IP Voice" images
• Release 12.3(14)T
• "IP Voice" images
VIC3-2E/M
• Release 12.4(15)XW or 12.4(20)T
• "IP Voice" images
• "IP Voice" images
VIC3-2FXS/DID
VIC3-2FXS-E/DID
VIC3-4FXS/DID
• Release 12.4(15)XZ or 12.4(20)T
• "IP Voice" images
• "IP Voice" images
If you are running IOS 15.X
If you are running IOS 15.X and above especially for Voice related items dont go for bare minumum. Try at least 384MB or 512MB depending on your load. I dont know what else you maybe running on it.
http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-packaging/product_bulletin_c25-557281.html
vic2-4fxo is not supported in
vic2-4fxo is not supported in 2800/3800 series
Anas
don't forget to rate helpful posts
Anasvic2-4fxo is  supported
Anas
vic2-4fxo is  supported in 2800
vic3-4fxo is not supported in 2800
670
