Bronze
VIC3-4FXS/DID Call Manager MGCP support
Anyone know if VIC3-4FXS/DID is supported MGCP Controlled VIC Endpoint with Call Manager version?
Hall of Fame Super Gold
Re: VIC3-4FXS/DID Call Manager MGCP support
Yes, it is.
Bronze
particular call manager version/SR required?
I don't think there is a requirement. CM doesn't really know what exact kind of card it is.
Bronze
Actually with MGCP Controlled Endpoints on a gateway it does have to be supported specifically in Call Manager usually but the good news is I just referenced a CM 6.1(2) and the VIC3-4FXS/DID is in the list.
Do you have a list or did you just look at the Call Manager. I am trying to figure out if a VIC3-2FXS/DID is supported in Call manager 4.2(3)SR3? Thanks in advance
Bronze
No unfortunately I never was never able to find a compatibility matrix. I just saw it under the particular CM Version that I was working on at the time.
I have a TAC case opened. They are researching the version.
Bronze
Just wanted to follow up on this, did you ever get a good compatibility matrix or anything for hardware to call manager software or any other good resource for this?
Hi Thomuff.
The TAC says to you what version support the VIC3-4FXS? My CCM is 4.1.x
Peterson
I'm having working VIC3-4FXS with MGCP (IOS 12.4.24T1) and CCM 7.0.2b
MC
716
