VIC3-4FXS/DID Card not recognized on Cisco 2811
Hi all,
I have a problem, I am already running a VIC2-4FXO Voice Card on Cisco Router 2811, this config is working fine.
Now, I have to add two more Voice Cards VIC2-2FXO and VIC3-4FXS/DID, and once I insert the cards and startup the router, the cards LEDs stay amber, the one working before still works but the new cards are not being detected or recognized by the Router i guess, I am dumping all the related info below, and would really appreciate it if some one could tell me if i have got something wrong, thank you in advance.
Asad Nizam
SHOW DIAG
       C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
        Port adapter is analyzed
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC133069TM
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-26920-05
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 04
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 87
        Hardware date code       : 20090729
        Chassis Serial Number    : FCZ133472AB
        Chassis MAC Address      : 0023.eb5b.fdc8
        MAC Address block size   : 24
        CLEI Code                : COMWL10CRA
        Product (FRU) Number     : CISCO2811
        Part Number              : 73-10258-05
        Version Identifier       : V06
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 33 33 30 36 39 54 4D 40
          0x10: 03 E7 41 01 00 C0 46 03 20 00 69 28 05 42 41 30
          0x20: 88 00 00 00 00 02 04 03 00 81 00 00 00 00 04 00
          0x30: 09 87 83 01 32 8F 69 C2 8B 46 43 5A 31 33 33 34
          0x40: 37 32 41 42 C3 06 00 23 EB 5B FD C8 43 00 18 C6
          0x50: 8A 43 4F 4D 57 4C 31 30 43 52 41 CB 8F 43 49 53
          0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 28 12
          0x70: 05 89 56 30 36 20 D9 02 40 C1 FF FF FF FF FF FF
        PVDM Slot 0:
        32-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
        Hardware Revision        : 4.0
        Part Number              : 73-8539-05
        Board Revision           : C0
        Fab Version              : 04
        PCB Serial Number        : FOC13460NE7
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM2-32
        Version Identifier       : V01
          0x00: 04 FF 40 03 EE 41 04 00 82 49 21 5B 05 42 43 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 33 34 36
          0x20: 30 4E 45 37 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 88 50 56 44 4D 32 2D 33 32 89 56 30 31 20 D9 02
          0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        2nd generation - FXO Voice daughter card (4 port)
        Hardware Revision        : 5.0
        Top Assy. Part Number    : 800-21589-04
        Board Revision           : B0
        Deviation Number         : 0-0
        Fab Version              : 04
        PCB Serial Number        : FOC14417BUQ
        RMA History              : 00
        Product (FRU) Number     : VIC2-4FXO
        Version Identifier       : V03
        CLEI Code                : CNUIAXJAAB
          0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 54 55 04
          0x10: 42 42 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 34 34 31 37 42 55 51 03 00 81 00 00 00 00 04 00
          0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 33 20
          0x40: C6 8A 43 4E 55 49 41 58 4A 41 41 42 FF FF FF FF
        WIC Slot 1:
        Unknown WAN daughter card
        WIC module not supported/disabled in this slot
        Top Assy. Part Number    : 800-27473-03
        Board Revision           : B0
        Fab Version              : 07
        PCB Serial Number        : FOC14164F1J
        RMA History              : 00
        Product (FRU) Number     : VIC3-4FXS/DID
        Version Identifier       : V02
        CLEI Code                : IPUIA6JRAB
        Longitudinal Calibration : 01 10 10 E5 9D 10 10 89
                                   73 10 10 A7 AA 10 10 81
                                   7F
          0x00: 04 FF 40 05 1B 41 01 00 C0 46 03 20 00 6B 51 03
          0x10: 42 42 30 88 00 00 00 00 02 07 C1 8B 46 4F 43 31
          0x20: 34 31 36 34 46 31 4A 03 00 81 00 00 00 00 04 00
          0x30: CB 8D 56 49 43 33 2D 34 46 58 53 2F 44 49 44 89
          0x40: 56 30 32 20 D9 02 40 C1 C6 8A 49 50 55 49 41 36
          0x50: 4A 52 41 42 D3 11 01 10 10 E5 9D 10 10 89 73 10
          0x60: 10 A7 AA 10 10 81 7F FF FF FF FF FF FF FF FF FF
        WIC Slot 2:
        Hardware revision 1.0           Board revision G0
        Serial number     31212920      Part number    800-05298-01
        FRU Part Number     VIC-2FXO-M1=
        Test history      0x0           RMA number     00-00-00
        Connector type    Wan Module
        EEPROM format version 1
          0x20: 01 2B 01 00 01 DC 45 78 50 14 B2 01 00 00 00 00
          0x30: 80 00 00 00 03 08 09 01 FF FF FF FF FF FF FF FF
SHOW INVENTORY
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V06 , SN: FCZ133472AB
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 0", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V03 , SN: FOC14417BUQ
NAME: "PVDMII DSP SIMM with Two DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with Two DSPs"
PID: PVDM2-32          , VID: V01 , SN: FOC13460NE7
SHOW VERSION
Cisco IOS Software, 2800 Software (C2800NM-ENTSERVICESK9-M), Version 12.4(15)T10, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 14-Sep-09 14:01 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
gateway uptime is 1 day, 21 hours, 25 minutes
System image file is "flash:c2800nm-entservicesk9-mz.124-15.T10.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.50) with 249856K/12288K bytes of memory.
Processor board ID FCZ133472AB
2 FastEthernet interfaces
4 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
SHOW VOICE DSP
DSP  DSP                DSPWARE CURR  BOOT                         PAK     TX/RX
TYPE NUM CH CODEC       VERSION STATE STATE   RST AI VOICEPORT TS ABORT  PACK COUNT
----------------------------FLEX VOICE CARD 0 ------------------------------
                           *DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending
TYPE  NUM CH CODEC     VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
C5510 001 01 g711ulaw     9.4.811 busy  idle      0  0 0/0/2     08    0         0/14
C5510 001 03 g711ulaw     9.4.811 busy  idle      0  0 0/0/0     00    0      891/935
                           *DSP SIGNALING CHANNELS*
C5510 001 01 {flex}       9.4.811 alloc idle      0  0 0/0/0     02    0       1242/0
C5510 001 02 {flex}       9.4.811 alloc idle      0  0 0/0/1     06    0       1051/0
C5510 001 03 {flex}       9.4.811 alloc idle      0  0 0/0/2     10    0        581/0
C5510 001 04 {flex}       9.4.811 alloc idle      0  0 0/0/3     14    0         36/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
1 ACCEPTED SOLUTION
Green
Looking at the IOS requirements you are using the T train
You need to upgrade to 20T at least
VIC3-2FXS/DID
VIC3-2FXS-E/DID
VIC3-4FXS/DID
• Cisco IOS Software
• Release 12.4(15)XZ or 12.4(20)T
• "IP Voice" images
I would recommend that you use the latest that fits your memory
ENTERPRISE SERVICES W/O CRYPTO
c2800nm-entservices-mz.124-24.T6.bin
Release Date: 31/AUG/2011
Size: 49882.58 KB (51079760 bytes)
Minimum Memory: DRAM:256MB   Flash:64MB
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
1 REPLY
Green
VIC3-2FXS/DID
VIC3-2FXS-E/DID
VIC3-4FXS/DID
• "IP Voice" images
Alex
1463
