Community Member
VIC3-4FXS/DID DSP Alarms upon PBX DID Port connection
I have done an integration between VIC3-4FXS/DID card with Meril Legend DID Card. I see alarms when the DID port of Legend PBX is connected to the FXS port. I used Loopstart for signaling while PBX used Immediate start signaling on DID. Provided the status of the FXS port as well. I kept at 600 ohms impedence
Jul  8 15:55:36.570: Power alarm on DSP channel ch=130 is OFF
0001 0000 **
Jul  8 15:55:39.862: Power alarm on DSP channel ch=130 is ON
0001 0001 **
Foreign Exchange Station 0/1/3 Slot is 0, Sub-unit is 1, Port is 3
Type of VoicePort is FXS  VIC3-4FXS/DID
Operation State is DORMANT
Administrative State is UP
No Interface Down Failure
Description is Outbound to Legend DID Trunk
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 128 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 15 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Supervisory Disconnect Time Out is set to 750 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for US
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Station name None, Station number 3147652000
Translation profile (Incoming):
Translation profile (Outgoing):
lpcor (Incoming):
lpcor (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Ring Frequency is 25 Hz
Hook Status is On Hook
Ring Active Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Hookflash-in Timing is set to max=1000 ms, min=150 ms
Hookflash-out Timing is set to 400 ms
No disconnect acknowledge
Ring Cadence is defined by CPTone Selection
Ring Cadence are [20 40] * 100 msec
Ringer Equivalence Number is set to 1
Hall of Fame Super Gold
If all works, you can ignore these as they are purely cosmetic.
Otherwise, try updating IOS.
