VIC3-4FXS/DID - no dial tone
Hi - Appreciate any help!
Have a 2821 running CUCME 7.1
VIC3-4FXS/DID is installed to provide analog connection for a fax machine however none of the FXS ports are providing dial tone. I've had a user plug an analog phone directly into each port of the FXS card and they don't hear any dial tone. Normally this is pretty standard, never seen an issue like this before - wondering if it is a hardware issue with the FXS card. Pasted some relevant config below:
show voice port summary
0/0/0           --  fxo-ls      up    dorm idle     on-hook  y
0/0/1           --  fxo-ls      up    dorm idle     on-hook  y
0/1/0           --  fxs-ls      up    up   off-hook idle     y
0/1/1           --  fxs-ls      up    up   off-hook idle     y
0/1/2           --  fxs-ls      up    up   off-hook idle     y
0/1/3           --  fxs-ls      up    up   off-hook idle     y
dial-peer voice 10 pots
destination-pattern 2495
port 0/1/0
Foreign Exchange Station 0/1/0 Slot is 0, Sub-unit is 1, Port is 0
Type of VoicePort is FXS  VIC3-4FXS/DID
Operation State is UP
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 128 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 15 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Supervisory Disconnect Time Out is set to 750 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for US
Everyone's tags (3)
I ran into a similar problem where after a period of time the FXS port just locked up even though IOS showed it was fine.  What version of IOS are you running?
Please help us make the communities better. Rate helpful posts!
Thanks for your reply!
IOS version is 15.0(1)M6
Green
Can provide the output of
Show version
Show diag
This may be DSP related
Alex
Regards, Alex. Please rate useful posts.
Thanks for your reply.....
LTI-GREENVILLE-CME#show ver
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 15.0(1)M6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 01-Jun-11 16:01 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
LTI-GREENVILLE-CME uptime is 9 weeks, 3 days, 15 hours, 29 minutes
System restarted at 18:35:42 EDT Sun Oct 16 2011
System image file is "flash:c2800nm-spservicesk9-mz.150-1.M6.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2821 (revision 53.51) with 507904K/16384K bytes of memory.
Processor board ID FTX1534AMNJ
2 Gigabit Ethernet interfaces
1 terminal line
2 Voice FXO interfaces
4 Voice FXS interfaces
1 cisco Integrated Service Engine(s)
   Cisco Unity Express 8.6.1 in slot 1
DRAM configuration is 64 bits wide with parity enabled.
191K bytes of non-volatile configuration memory.
126976K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2821             FTX1534AMNJ
LTI-GREENVILLE-CME#show diag
Slot 0:
        C2821 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
        Port adapter is analyzed
        Port adapter insertion time 9w3d ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC15286V9W
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-26921-07
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 03
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 87
        Hardware date code       : 20110725
        Chassis Serial Number    : FTX1534AMNJ
        Chassis MAC Address      : 1caa.076a.1940
        MAC Address block size   : 32
        CLEI Code                : COMHS00ARB
        Product (FRU) Number     : CISCO2821
        Part Number              : 73-8853-07
        Version Identifier       : V08
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 35 32 38 36 56 39 57 40
          0x10: 03 E8 41 01 00 C0 46 03 20 00 69 29 07 42 41 30
          0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00
          0x30: 09 87 83 01 32 DD 85 C2 8B 46 54 58 31 35 33 34
          0x40: 41 4D 4E 4A C3 06 1C AA 07 6A 19 40 43 00 20 C6
          0x50: 8A 43 4F 4D 48 53 30 30 41 52 42 CB 8F 43 49 53
          0x60: 43 4F 32 38 32 31 20 20 20 20 20 20 82 49 22 95
          0x70: 07 89 56 30 38 20 D9 03 40 C1 C2 FF FF FF FF FF
        PVDM Slot 0:
        48-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
        Hardware Revision        : 4.0
        Part Number              : 73-8540-05
        Board Revision           : C0
        Fab Version              : 04
        PCB Serial Number        : FOC1528585P
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM2-48
        Version Identifier       : V01
          0x00: 04 FF 40 03 ED 41 04 00 82 49 21 5C 05 42 43 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 35 32 38
          0x20: 35 38 35 50 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 88 50 56 44 4D 32 2D 34 38 89 56 30 31 20 D9 02
          0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        2nd generation - FXO Voice daughter card (2 port)
        Hardware Revision        : 5.0
        Top Assy. Part Number    : 800-33584-01
        Board Revision           : C0
        Deviation Number         : 0-0
        Fab Version              : 04
        PCB Serial Number        : FOC15153T1B
        RMA History              : 00
        Product (FRU) Number     : VIC2-2FXO
        Version Identifier       : V03
        CLEI Code                : CNUIARTAAC
          0x00: 04 FF 40 00 4D 41 05 00 C0 46 03 20 00 83 30 01
          0x10: 42 43 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 35 31 35 33 54 31 42 03 00 81 00 00 00 00 04 00
          0x30: CB 89 56 49 43 32 2D 32 46 58 4F 89 56 30 33 20
          0x40: C6 8A 43 4E 55 49 41 52 54 41 41 43 FF FF FF FF
        WIC Slot 1:
        3rd generation - FXS DID Voice daughter card (4 port)
        Top Assy. Part Number    : 800-33583-01
        Board Revision           : D0
        Fab Version              : 07
        PCB Serial Number        : FOC15306HC6
        RMA History              : 00
        Product (FRU) Number     : VIC3-4FXS/DID
        CLEI Code                : IPUIA6JRAC
        Longitudinal Calibration : 01 10 10 B5 B9 10 10 46
                                   7F 10 10 4E 9F 10 10 6F
                                   84
          0x00: 04 FF 40 05 1B 41 01 00 C0 46 03 20 00 83 2F 01
          0x10: 42 44 30 88 00 00 00 00 02 07 C1 8B 46 4F 43 31
          0x20: 35 33 30 36 48 43 36 03 00 81 00 00 00 00 04 00
          0x30: CB 8D 56 49 43 33 2D 34 46 58 53 2F 44 49 44 89
          0x40: 56 30 33 20 D9 02 40 C1 C6 8A 49 50 55 49 41 36
          0x50: 4A 52 41 43 D3 11 01 10 10 B5 B9 10 10 46 7F 10
          0x60: 10 4E 9F 10 10 6F 84 FF FF FF FF FF FF FF FF FF
Slot 1:
        Integrated Service Engine Port adapter, 1 port
        Part Number              : 73-10371-04
        Top Assy. Part Number    : 800-35481-01
        Board Revision           : A0
        Fab Version              : 01
        PCB Serial Number        : FOC15294J7G
        RMA History              : 00
        Product (FRU) Number     : NME-CUE
        Version Identifier       : V04
        CLEI Code                : IPUIBEVRTC
          0x00: 04 FF 40 04 F8 41 01 00 82 49 28 83 04 C0 46 03
          0x10: 20 00 8A 99 01 42 41 30 88 00 00 00 00 02 01 C1
          0x20: 8B 46 4F 43 31 35 32 39 34 4A 37 47 03 00 81 00
          0x30: 00 00 00 04 00 CB 87 4E 4D 45 2D 43 55 45 89 56
          0x40: 30 34 20 D9 03 40 C1 CB C6 8A 49 50 55 49 42 45
          0x50: 56 52 54 43 FF FF FF FF FF FF FF FF FF FF FF FF
         - Integrated Service Engine Daughter Card.
        Part Number              : 73-10372-01
        Top Assy. Part Number    : 800-34644-01
        Board Revision           : A0
        Fab Version              : 01
        PCB Serial Number        : FOC15294J1G
        RMA History              : 00
          0x00: 04 FF 40 04 F9 41 01 00 82 49 28 84 01 C0 46 03
          0x10: 20 00 87 54 01 42 41 30 88 00 00 00 00 02 01 C1
          0x20: 8B 46 4F 43 31 35 32 39 34 4A 31 47 03 00 81 00
          0x30: 00 00 00 04 00 D9 02 40 C1 FF FF FF FF FF FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Green
I se from the show version that the router has been up since
Did you install the card with the router powered up.
Looking at the link
http://www.cisco.com/en/US/docs/routers/access/interfaces/ic/hardware/installation/guide/inst_ic.html#wp1036682
Table 1
POWER OFF ROUTER
If this has not been folowed than the card may be damaged
If you have not already done so I advise you to
"copy run start" and then repower the router at a suitable time
Then try testing the fxs ports again
Alex
No I did not. When we originally installed the router, we were unsure if a fax was needed at that time so the card was just left alone. It was determined by the business that they need a fax so I configured the port and....no dice.
Green
Hi Again,
I have tried searching for bugs re the FXS ports being stuck in offhook and therefore no dial tone.
Plenty if it were FXO but not relevant to you.
I can only suggest a repower at a suitable time, then retest
Your IOS 15.0.1M6 is still downloadable although M7 is released now too.
You could try an IOS upgrade to M7
If this still fails then a TAC should be raised.
Alex
Thanks for your research -
I just tried shutting down the router and moving the FXS card to another slot. Still am not getting any dial tone from any of the FXS ports. It is so weird because during the boot up process I see log messages hat the card was seen and that DSP resources were be allocated accordingly
DSP groups on slot 0:
dsp 1:
  State: UP, firmware: 26.3.9
  Max signal/voice channel: 16/16
  Max credits: 240
num_of_sig_chnls_allocated: 6
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 240, reserved credits: 0
   Signaling channels allocated: 6
    Voice channels allocated: 0
    Credits used (rounded-up): 0
I highly doubt this could be the case but, could my SIP configuration (SIP trunk to outside) be affecting how the card is acting? This is the first time I've used a SIP trunk with CME....
Based on this thread so far it sounds like you have a DoA card but never knew it.  However, there are a couple more things to try first...
Ensure "voice-port 0/1/0" is not shutdown and that there aren't any other non-standard commands on it. In fact please post a copy of the voice-port 0/1/0 config.
So far you've only said you don't hear dial-tone on the port.  Have you tried removing the dial-peer voice 10 and applying the directory number 2495 directly to the port like this:
  voice-port 0/1/0
   connection plar 2495
With or without the dial-peer, what happens if you dial 2495 from another phone?  Does it ring?
Turn on 'debug vpm all' and try to take the phone off-hook or dial 2495 from another phone.  Attach the results to your next post.
-Steven
I moved the card in a previous troubleshooting step so the ports in question are now actually 0/3/0 - 0/3/3...
LTI-GREENVILLE-CME#show run | be voice-port 0/3/0
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
All (4) ports are stuck in UP/off-hook status regardless of what I configure on them...
LTI-GREENVILLE-CME#show voice port summary
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/3/0           --  fxs-ls      up    up   off-hook idle     y
0/3/1           --  fxs-ls      up    up   off-hook idle     y
0/3/2           --  fxs-ls      up    up   off-hook idle     y
0/3/3           --  fxs-ls      up    up   off-hook idle     y
I've also notied that when I do a 'show voice call summary', the ports show vpm status of FXSLS_PARK
LTI-GREENVILLE-CME#show voice call summary
PORT           CODEC     VAD VTSP STATE            VPM STATE
0/0/0         -          -  -                     FXOLS_ONHOOK
0/0/1         -          -  -                     FXOLS_ONHOOK
0/3/0         -          -  -                     FXSLS_PARK
0/3/1         -          -  -                     FXSLS_PARK
0/3/2         -          -  -                     FXSLS_PARK
0/3/3         -          -  -                     FXSLS_PARK
Tom
Tom,
It sure looks like the FXS card is stuck.  I tend to agree with Alex's assertion.  Upgrade to 15.0(1)M7 and reboot.  The only other thing to try ahead of that is doing a shut / no shut on each of the 0/3/X voice-ports and see if that resets them.
If the problem continues, call TAC.  You may have a bad card.
-Steven
*** UPDATE ***
I opened a TAC case and after trying their suggetions (everything I already tried) we ended up change the IOS from 15.0(1)M6 to 12.4(24)T6. This fixed the issue immediately and the FXS card stated acting normal. The TAC engineer did not mention any known bug...........but beware.
Thanks for everyones help!
Tom
Hall of Fame Super Gold
That much for an IOS train that is classified "Main Deployment".
3084
