VIC3-4FXS/DID not recognized 2811
I have a CISCO2811 with c2800nm-advipservicesk9-mz.124-21.bin and 1 PVDM2-16.
In one of the HWIC slots I have a VIC3-4FXS/DID= card and the router won't recognized it.
I also have a VIC-4FXS card(older model) and that one works jsut fine.
I am thinking is the IOS version, but not sure.
Any help greatly appreciated.
  • IP Telephony
Hall of Fame Super Gold
Re: VIC3-4FXS/DID not recognized 2811
You need to update IOS.
Mainline won't have support for that card.
Run 12.4(20)T or higher to get support, as per:
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd8057f2e0.pdf
I'd recommend going to the latest rebuild of 15.0(1)M if you're going to change code, since that throttle is a mainline throttle and will be sustained for stability through the next couple years.  Otherwise, 12.4(24)T4 would be the next best choice.
As alternative to 15.0M, my recommendation is 12.4(22)YB6.
The advantage is that it does not requires a memory upgrade.
Try 15.1(1)T.  I've installed this on a router with 512 DRAM for >6 months and works pretty well.  I have PVDM2 and VWIC-1MFT installed.
This card should work in any of the 4 HWIC slots correct?
there should be no need to have NM module?
Thanks for your responses.
I just installed c2800nm-advipservicesk9-mz.124-25.bin
It won't recognized the VIC3-4FXS/DID=. I have moved it to one of the other 4 slots and same issue.
This IOS version should recognize this card.
I loaded the correct IOS as suggested:
c2800nm-advipservicesk9-mz.124-24.T4.bin
This one worked.
Thanks for your help.
2963
