Community Member
video calls are not secure - not showing lock icon
Hi guys,
Calls between 9971/8945. Video calls are not getting secured.
video calls are not secure - not showing lock icon.
However audio calls are secure
CUCM Version : 8.6.2.22900-9
1 pub and 2 sub
Secured cluster : mixed mode
9971 : sip9971.9-3-1-33 - running version - same issue
9971 : sip9971.9-2-4-19 - old version - same issue
8945 : sccp8941-8945.9-3-2-11 – Running version.
Please suggest.
thx
Ashish
Thanks for pointing this out.  It looks like you have a case open for this currently too.  I'll test this out on Monday, but in the mean time if you want to test something, try and change the Cisco CallManager service parameter for "
Override BFCP Application Encryption Status When Designating Call Security Status".  This should show the lock icon since CUCM will only check the security status of the audio stream to determine if the lock should be shown or not.  Before doing this of course I'd check with a packet capture to make sure the video is indeed encrypted before doing this.
Would you be able to try 9.3(2) firmware or later?  I checked with 9.4(1) and I see a lock icon when placing a video call on my 9971.  According to the new and changed information 9.3(2) added additional support for when to display the lock icon,
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/9971_9951_8961/firmware/932/release_notes/P567_BK_RD4ECA70_00_rn-9_3_2-8961-9951-9971_chapter_00.html#P567_RF_AB412E9F_00.
180
