Video enabling phones via BAT UCM7.x
mlucas1911
Level 4
Level 4
Hey all,
I have a UCM 7.x cluster with about 230 devices. I need to video enable all my 7970s and IP Communicators. Does anyone know of a way to bulk update this?
Thanks in advance!!
Mike
6 Replies 6
Jaime Valencia
Select Update phones, choose the phones you want and then check the Video Capabilities field and change it to Enabled.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Except that it isn't available as an option.
Not sure what you're doing, but the option IS there
java
If this helps, please rate
java
I was going to call schnanigans except when i looked in mine -- that's missing!   That entire section is missing.
BTW:  i'm on 7.1.3.2000-2
Any thoughts?
Any thoughts?
See attachment
