12-17-2013 03:48 AM - edited 03-16-2019 08:54 PM
I call between CIPT(sccp) to CIPT(sccp) follow this connection CIPT-CUCM-siptrunk-CUBE-siptrunk-CUCM-CIPT
*** CUCM sip trunk config I need check box "Early Offer support for voice and video calls (insert MTP if needed)" in SIP Profile
When call connected have audio only no video popup, in SIP message not have m=video
But when I uncheck box "Early Offer support for voice and video calls (insert MTP if needed)" video is popup and fine
==CUBE config==
dial-peer voice 1001 voip
description *** Call to CUCM86 ***
session protocol sipv2
incoming called-number 1...
voice-class codec 1
dtmf-relay sip-kpml sip-notify
dial-peer voice 2001 voip
destination-pattern 1...
session target ipv4:10.0.253.76
voice-class codec 1
dtmf-relay sip-kpml sip-notify rtp-nte
==CUBE debug ccsip message==
Dec 17 11:41:16.523: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:1002@10.0.253.77:5060 SIP/2.0
Via: SIP/2.0/TCP 10.0.253.76:5060;branch=z9hG4bK15766340e64
From: <sip:1001@10.0.253.76>;tag=160~ddaa1625-63b0-4d43-9cf2-16b0ca2a9c8e-29367879
To: <sip:1002@10.0.253.77>
Date: Tue, 17 Dec 2013 11:43:29 GMT
Call-ID: 71518c00-2b0138e1-2e-4cfd000a@10.0.253.76
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM9.0
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:10.0.253.76:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 1901169664-0000065536-0000000046-1291649034
Session-Expires: 1800
P-Asserted-Identity: <sip:1001@10.0.253.76>
Remote-Party-ID: <sip:1001@10.0.253.76>;party=calling;screen=yes;privacy=off
Contact: <sip:1001@10.0.253.76:5060;transport=tcp>
Max-Forwards: 70
Content-Type: application/sdp
Content-Length: 380
v=0
o=CiscoSystemsCCM-SIP 160 1 IN IP4 10.0.253.76
s=SIP Call
c=IN IP4 10.0.9.205
b=TIAS:64000
b=AS:64
t=0 0
m=audio 24644 RTP/AVP 0 8 116 18 101
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:8 PCMA/8000
a=ptime:20
a=rtpmap:116 iLBC/8000
a=ptime:20
a=maxptime:60
a=fmtp:116 mode=20
a=rtpmap:18 G729/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Dec 17 11:41:16.527: //-1/71518C000000/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
Dec 17 11:41:16.527: //182/71518C000000/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.253.77
Dec 17 11:41:16.527: //182/71518C000000/SIP/Media/sipSPIUpdCallWithSdpInfo:
Preferred Codec : g711ulaw, bytes :160
Preferred DTMF relay : sip-kpml
Preferred NTE payload : 98
Early Media : No
Delayed Media : No
Bridge Done : No
New Media : No
DSP DNLD Reqd : No
Dec 17 11:41:16.527: //182/71518C000000/SIP/Media/sipSPISelectCodecVersion: g729br8 flavor of g729 codec will be used
Dec 17 11:41:16.527: //182/71518C000000/SIP/Media/sipSPIDisplayStreamInfo:
Stream type : voice-only
Media line : 1
State : STREAM_ADDING (2)
Stream address type : 1
Callid : 182
Peer Callid : -1
RTP/SRTP Negotiated : 8
Negotiated Codec : g711ulaw, bytes :160
Nego. Codec payload : 0 (tx), 0 (rx)
Negotiated DTMF relay : sip-kpml
Negotiated NTE payload : 0 (tx), 0 (rx)
Negotiated CN payload : 0
Media Srce Addr/Port : [10.0.253.77]:0
Media Dest Addr/Port : [10.0.9.205]:24644
Media line : 1
Callid : 182
Dec 17 11:41:16.527: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 23880 for stream 1
Dec 17 11:41:16.531: //182/71518C000000/SIP/Media/sipSPIDisplayStreamInfo:
Media line : 1
Callid : 182
Peer Callid : -1
Media Srce Addr/Port : [10.0.253.77]:23880
12-17-2013 03:59 AM
Video is certainly supported with sip early offer. You will need to collect cucm traces and send over to see whats going on
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
