Video via Inter-Cluster Trunk (Non-Gatekeeper Controlled) with Media Termination Point Required
Hi Outthere,
We've tow CUCM Cluster connected via a Inter-Cluster Trunk (Non-Gatekeeper Controlled). We use the Option Media Termination Point Required.
An Cisco IOS Enhanced Software Media Termination Point works on both sides.
For audio-calls everything works fine!
Now we want to use video-call.
The MTP is in passthrough mode.
Regions und Locations are also conigured.
What else do we need and what are the options to troubleshoot it?
1 ACCEPTED SOLUTION
Re: Video via Inter-Cluster Trunk (Non-Gatekeeper Controlled) wi
Cisco Unified CM Release 5.0 introduced audio transcoding resources  based on Cisco IOS Enhanced Media Termination Point, which are able to  support transcoding the audio stream of a video call while still  supporting the video stream via a pass-through codec. The pass-through  codec is used only for the video stream because the pass-through codec  cannot be used for a stream that requires transcoding. The following  three conditions must all be true for the pass-through codec to be used:
The two endpoint devices have a  matching CODEC capability.
MTP Required is not checked for either endpoint.
All intermediate resource devices (MTPs  and transcoders) support the pass-through codec.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/video.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Sorry I forgot some interresting details:
CUCM System version: 6.1.4.2228-1
MTP: Voice Router with Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 12.4(24)T3
dspfarm profile 9 mtp
description MTP for ICT passthrough and G729r8
codec pass-through
codec g729r8
maximum sessions software 100
associate application SCCP
java
java
Thanx for your help!
464
