Viewing Log for Call Manager
Yesterday my call manager publisher & subscriber got restarted automatically. Other netowrking devices connected to the same power source where CCM was pluged, didn't get reloaded. It means there was no issue from the power side.
Can anybody kindly guide me whereto look for the logs so that i can find the reason for such abnormal behaviour...
1 ACCEPTED SOLUTION
Re: Viewing Log for Call Manager
Start by looking at the app log
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
The App Log is in CUCM or in RTMT?? Can you plz suggest..
Everything is in CUCM, RTMT is the tool you use to view/gather the stuff
java
java
Thanks Java..
421
