ViewMail and Outlook 2007
Does anyone know how to make ViewMail 4.1 work with Outlook 2007 or if there is a new version of ViewMail that will work with Outlook 2007?
Any info would be appreciated!
Scott Turner
Re: ViewMail and Outlook 2007
I second that question, I have been waiting to move to UM partially for this very reason.
Green
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_device_support_table09186a0080531eba.html#wp34316
Since Outlook 2007 is not officially listed in Cisco Compatibility Matrix,
it is not officially supported by Cisco at this time. You should have contact with your Cisco Sales Engineer and request for a more specific date of release the viewmail that is compatible with Outlook 2007.
Afaik ViewMail that supports Outlook 2007 will be released ninety days after the Office 2007 is released.
http://office.microsoft.com/en-us/products/HA101741481033.aspx
VMO 4.2.2 works with Office 2007
Hi, I try to install VMO 4.2.2 on a fresh installed laptop, Office 2007 is already install on this PC. Do you know if I can install VMO ? When I try to install it, the installer said that he can't found the outlook....Do it only work when you upgrade from 2003 to 2007, not for a fresh install ??
Thanks for your help !
Hi -
You may already have discovered this ... ViewMail 5.0 client is compatible with Unity server version 4.2. VMO 5.X supports Outlook 2007 and Vista (see the release notes for further details).
Ginger
575
