Viewmail for lotus notes - Issue with installation
Hello there,
We just did an upgrade from an older version of unity and call manager (4 to 9)
There unity was tied to lotus notes.
We are having an issues configuring the Viewmail for lotus notes client.
we are using the following installation guide
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/vmn/release/notes/851cucvmnrn.html
on the
Creating a ViewMail for Notes Account in Notes section
step 2 (we are using notes 8.5)
it says from the file menu select open then lotus notes application then Install VMN
that menu option is not there at all.  Please help
we have a menu under file then application.  however there is not Install VMN option
we are on connection 9.1.1a however the issue seems to be with the client not matching up on the install instructions
thanks
1 REPLY
Please check the below docs . Looks like the EOL for IBM lotus with cisco UC has
ended a long time back.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps9830/end_of_life_notice_c51-546834.html
http://www.cisco.com/en/US/products/sw/voicesw/prod_category_end_of_life.html
The above is the reason why you probably do not see the install VMN option.
Hope that helps!
Karthik Sivaram
178
