Viewmail outlook with Citrix
Does anyone know if Cisco supports Viewmail if the user is running Outlook from Citrix server.
Thank you
Everyone's tags (3)
1 REPLY
You can review the Release Notes for the VMO client you're interested in using, they contain the PC requirements and will mention if it's supported on Citrix or other HVDs. If it's not mentioned, it's not supported.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
373
