Virtual IP PBX
Greetings!!!
I have a query regarding Virtual IP PBX,my Question is
1.Can v use a Carrier grade network platform(SIP based communication) that serves a Virtual hosted IP PBX over the Internet/MPLS cloud using SIP which communicates with the Cisco IP phones & PSTN gateways, thereby eliminating the need for a PBX or IP PBX on customer premises?
2.If yes, then what is exact procedure?
Looking forward 4 ur prompt response ASAP.
Brgds,
Arif.
1 REPLY
Hall of Fame Super Gold
Re: Virtual IP PBX
You can do that but is poor solution, because you will never have the full features and control that you have with a local device, that is also cheap and effective like a CME router.
Moreover, if the Internet circuit fails, none of the telephones will work. That is bad.
399
