Virtual Memory 90%
The CCM got VM above 90%. I already restarted the Cisco Tomcat, but the issue still happens, some could provide more detail to solve my problem. I will appreciate any help.
admin:show process using-most memory
MEM(K) PID  ARGS
77944 8880 /usr/local/cm/bin/rtmtreporter /usr/local/cm/conf/rtmtReporterCfg.xml
78180 7049 /usr/local/cm/bin/carschlr /usr/local/cm/conf/car/carschlrCfg.xml
142292 7791 /usr/local/cm/bin/cmoninit
363328 8787 /usr/local/cm/bin/ccm
456368 3707 /home/tomcat/tomcat /home/tomcat/tomcatJlauncherConfig.xml -Djava.li        brary.path=/usr/local/lib:/usr/local/thirdparty/java/j2sdk/jre/lib/i386:/usr/loc        al/thirdparty/java/j2sdk/jre/lib/i386/server:/usr/lib/pgsql:/usr/lib:/usr/local/        cm/lib::/usr/local/platform/lib -XX:ErrorFile=/usr/local/thirdparty/jakarta-tomc        at/logs/diagnostic-info.jvm-crash.<pid>.tomcat.txt -XX:OnOutOfMemoryError=/home/        tomcat/tomcat_diagnostics.sh -XX:OnError=/home/tomcat/tomcat_diagnostics.sh -Dja        va.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Djava.util.loggin        g.config.file=/usr/local/thirdparty/jakarta-tomcat/conf/logging.properties -Xmx5        12m -Xms256m -XX:MaxPermSize=128m -Djava.endorsed.dirs=/usr/local/thirdparty/jak        arta-tomcat/endorsed -classpath :/usr/local/thirdparty/java/bcprov-jdk16-143.jar        :/usr/local/platform/jar/xalan.jar:/usr/local/platform/jar/certMgmt.jar:/usr/loc        al/platform/jar/certMonitor.jar:/usr/local/platform/jar/Iproduct.jar:/usr/local/        platform/jar/Ihardware.jar:/usr/local/platform/jar/CiscoIPSec.jar:/usr/local/pla        tform/jar/ciscoCmd.jar:/usr/local/platform/jar/ciscoCommon.jar:/usr/local/platfo        rm/jar/platform-api.jar:/common/download:/usr/local/platform/application_locale/        platform-api:/usr/local/platform/application_locale/cmplatform:/usr/local/cm/jar        /commons-logging.jar:/usr/local/cm/application_locale/cmservices:/usr/local/cm/a        pplication_locale/car:/usr/local/cm/application_locale/ccmadmin:/usr/local/cm/ap        plication_locale/ccmuser:/usr/local/cm/application_locale:/usr/local/thirdparty/        jakarta-tomcat/bin/bootstrap.jar:/usr/local/thirdparty/jakarta-tomcat/bin/bootst        rap.jar -Djava.security.manager -Djava.security.policy==/usr/local/thirdparty/ja        karta-tomcat/conf/catalina.policy -Dcatalina.base=/usr/local/thirdparty/jakarta-        tomcat -Dcatalina.home=/usr/local/thirdparty/jakarta-tomcat -Djava.io.tmpdir=/us        r/local/thirdparty/jakarta-tomcat/temp start
MEM(K) PID  ARGS
Thank you.
1 ACCEPTED SOLUTION
Virtual Memory 90%
Marcos,
1. What is the complete CUCM version & hardware model used ?
2. Is it for lab or production purpose ?
3. Did you use OVA file while installing the CUCM or the resources were allocated manually ? If manually, could you detail the allocation ?
GP.
Virtual Memory 90%
Marcos,
GP.
Virtual Memory 90%
Gajanan,
1. My CUCM version is 7.1.5.33900-10 and hardware model is HW Platform: 7835H2
2. This server is in production in a big company.
3. This server was install a log time before and i do not know if this resource were allocated manually. Could you help me how can i do do get this information?
Since now I appreciate your help.
Thank you!
MC
Virtual Memory 90%
MC,
Thanks for the details. Pls ignore my 3rd question as I thought it's Virtualized CUCM.
Do you mean, you see this high memory usage even after rebooting the server ? If not, could you check if the reboot helps lowering it down ? Appears like a memory leak issue.
GP.
Pls rate helpful posts by clicking on stars below the post !!
Virtual Memory 90%
Hi GP,
I reseted the server, and the virtual memory goes down to 70%. After 4 days the VM is increasead to 82%. I Read that the version of CCM 7.1.5.33900-10 has a bug. Do you know about anything about this issue. Could you provide any information about how solve this problem?
Thanks a lot!
MC
Virtual Memory 90%
Hi Marcos,
                   Usually when this occurs, it is always preferred to take a look at the process which is eating up all the memory resource.
use the below commands to  get an idea which process it is.
i)  show process using-most memory
ii)  show process load memory
iii) show status
iv) show hardware
Most often than not "Cisco Tomcat Service"  is the culprit. if you see that  then restart that particular service and it will solve the issue. you can collect the logs "Tomcat catalina.out" from RTMT to confirm this. (Usually its the TAC or the BU who does this job as they can read the logs well ))
One of the example is
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtj50884
Also sometimes Rogue registration attempts cause CUCM high Virtual Memory and Core dumps. For which you can collect the Event-viewer application log/ Event viewer system log and  from RTMT tool to know the ip addresses of the devices which are causing this.
So it will be clearer from the logs as to what is it that is causing this issue
hope this helps.
Please rate helpful posts !!!
Abdul
1267
