VLAN Issue in IP Phones
I am facing a VLAN issue in IP Phones. We have a default vlan, data vlan and voice vlan. When I configure the phones for data and voice vlans, the IP Phones takes the correct IP address from voice dhcp but it does not get register. It gets correct default router, TFTP, DHCP and dns. But it is not getting registered. I use the following commands to configure both data and voice vlan after creating the respective vlans. But when these vlans are removed the phones gets registered. I am configuring these commands in a L2 3750 cisco switch. We also have a 4900 L3 switch.
interface gigabitethernet 1/0/8
switchport mode access
switchport access vlan 10
switchport voice vlan 100
exit
But when I went through the CME admin guide it shows a different set of commands instead of the above given commands. The conf in cme admin guide is as follows.
macro global apply cisco-global
interface slot-number/port-number
macro apply cisco-phone $AVID number $VVID number
macro apply cisco-router $NVID number
end
Kindly advice.. Thanks in advance
I am using a CME here..
If your phone is getting the correct IP, gateway, tftp etc I suspect your port configuration is working fine.
If the phone is not registering to the CME i would check that
1.  the IP address of the tftp server (the cme in this case), default gateway, subnet mask, etc is correctly defined in the dhcp server.
2.  is the phone defined correctly on the CME?  I would double check the mac address on the ephone in cme is correct
3.  Can you ping the CME from the vlan the phone is on?
Does the phone display a specific message such as "registration rejected"?
thanks,
James
Hi James,
Thanks for the reply.
This is my dhcp conf in the cme.
ip dhcp pool VOICE
import all
network 10.60.100.0 255.255.255.0
option 150 ip 10.60.100.10
default-router 10.60.100.254
dns-server 10.60.1.10
Ans.) YEs. Its correctly defined in the dhcp server.
Ans.) Yes the phone is defined correctly on the cme. Because when i remove those vlans the phone gets registered.
Ans.) That I have not checked. Will check and let you know.
No.. I am not able to ping the ip of cme (10.60.100.10) from the switch..
I can ping to the gateway ip (10.60.100.254)
Whats the IP address of the switch?  is it on the same 10.60.100.0 subnet the phones are on?
281
