Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
VM Mailbox issue
Dear Team,
Sometime I am facing issue with VM mailbox  while importing to unity server ,  when i assign VM proofile  to extension  in device profile and trying to import in unity connection server it does not display and in that case i have to create mailbox manually.
i unable to uinderstand what could be the cause but its a issue
Please help.
hari
hari
Hall of Fame Super Silver
Unity and CUCM administration
Unity and CUCM administration is independent, when you assign voicemail profile to a DN in CUCM it has no bearing on Unity. You need to import/add the user in Unity seperately, unless this is BE5K where it is driven by end user configuration in CUCM.
HTH,
Chris
Thanks Chris,But my query is
Thanks Chris,
But my query is why such type of issue coming while importing mailbox in unity.
Either it could be sync issue or something else.
please suggest for best solutions because its a big deal to create mailbox manually.
hari
When you say "importing" is
When you say "importing" is this through LDAP?
are you saying this sometimes works, where other users you cant import through that same LDAP scheme?
Only thing that I can think of is that you have applied some custom filter in Unity that prevents a certain user from being imported.
for the rest, like Chris mentioned, there is no correlation between the 2.
Please remember to rate useful posts, by clicking on the stars below.
Hi Minkdennis,No LDAP in
Hi Minkdennis,
No LDAP in there, my process is to import the VM mailbox by search thrugh extension and then import. But the issue is when i go for serch sometimes extension does not display thats why i wanted to know about the problem and solution regarding this.
regards
Hari
hari
84
